Home > Maintenance & Modifications > Dynamic response light on red no adjustable suspension
Gilly1
Hi, me again, don't no if its coinsidence but had alternator fitted last couple days, today the dynamic response light has come on suspension not raising or lowering, do not drive over 30. I checked fuses and all ok, changed battery with new alternator, checked voltage and ignition off its 12.8v and running it 13.9v any ideas. Crying or Very sad
Post #518142 Sat Feb 18 2017 7:37pm
Is the fluid ok in that container by the airbox
Post #518148 Sat Feb 18 2017 7:57pm
DrRob
Not sure but Steve Norman is your local guru Thumbs Up
http://www.tandsnorman.com Visitor from fullfatrr.com
Post #518149 Sat Feb 18 2017 8:01pm
Gilly1
Yes checked level in bottle near airbox, all correct, I'm so confused.com this beast is really trying me at moment... Big Cry
Post #518159 Sat Feb 18 2017 9:35pm
Read fault codes.
Is the light yellow or red
Post #518162 Sat Feb 18 2017 9:58pm
Gilly1
Unfortunately not got access to code reader anymore, will have to get codes read by garage. 😔 the light is red.
Post #518169 Sat Feb 18 2017 10:47pm
Socast
Could be cause by all sort's. The fact you've had an alternator changed and it's just gone might be a coincidence, or the garage that were changing it may have disturbed the ABS sensor while doing the job. If you've had the tracking done that could have thrown it out.
Does the 4x4 info screen show all 4 wheels as being the same height (on level ground of course) ?
Post #518317 Mon Feb 20 2017 8:46am
Gilly1
Hi, mechanic went in through the front to change alternator but did have to undo dynamic response (ACE) pump to make room to remove alternator, 4x4 screen seems all ok, car states standard height, car looks standard height. All looks level on screen and outside.
Post #518318 Mon Feb 20 2017 8:56am
DrRob
He may have disturbed something/not put it back right hence the warning.....? Visitor from fullfatrr.com
Post #518320 Mon Feb 20 2017 9:43am
Gilly1
Yes, hopefully it's simple fix Bow down will mention it to garage this morning when give them a call. Thumbs Up
Post #518321 Mon Feb 20 2017 10:08am
Camelrock
Are you sure you have dynamic response on the car ? As its only fitted to TDV8's and S/C's as standard. Was an extra on the V6's. The light on the dash can come on with General sus faults as I found out the other day working on a basic disco 3 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #518330 Mon Feb 20 2017 11:12am
Gilly1
Hi, yes def got dynamic response, I've got the filler resiviour to the left of rad, by air box & I've got the pump directly bellow alternator, think the car had few extras when purchased new, it's got Brembo front brakes and 20" wheels. Hoping it is just a standard height sensor or similar, could it be air compressor failure as the front did raise very slow the last time I used it and got message (suspension raising slowly) thought that may of been because I went through the raise & lower procedure a couple times without letting compressor have min to recoupe.
Post #518332 Mon Feb 20 2017 11:35am
Gilly1
Just got call from garage, they have done diagnostics and come up blank, they said it looks like it's a faulty alternator as it's overcharging and looks like it's shut down the suspension. I've tried calling advance factors but the number provided on invoice says no longer in service, can anyone point me in the right direction to contact them..
Post #518336 Mon Feb 20 2017 12:18pm
Socast
That's crap, When they removed the ACE pump did they disconnect the hydraulic pipes ?
The ACE system is self bleeding but needs to be "convinced" to take oil. When I replaced my ACE pump it didn't want to draw oil under it's own volition. I had to pressurise the reservoir to get oil back into the pump.
There will be fault codes relating to low pressure from the ACE system. I'm in Somerset (Taunton) where are you taking it too ?
My money is on it either being an air locked pump or more likely that the mechanic hasn't routed the auxilary belt correctly.
Post #518337 Mon Feb 20 2017 12:27pm
Socast
You will need a new compressor soon... You might be lucky and it'll be the air drier that needs replacement.
Post #518338 Mon Feb 20 2017 12:29pm
