Home > Maintenance & Modifications > Do you need lift the body to get heads off 4.2 supercharged
AnimalMother
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
I've got valve problems with my 4.2 supercharged AJV8 due to running LPG for about 70k miles.
We've made a start on stripping it down, supercharger and inlets off.
Just looking at the exhaust manifolds and wondering if it's possible to remove heads while engines in situ.
Does anyone know if you have to lift the body to get the heads off on a supercharged?
Post #517289 Fri Feb 10 2017 9:02am
On a diesel you take the heatshields off inside the wheel arch (what fun!) and then use long extensions to get to the manifold bolts and EGR bolts.
Post #517304 Fri Feb 10 2017 12:10pm
d-9
Once you have stripped the heads off, please post some pictures, it would be good to see some evidence of the damage that LPG does to these engines.
Post #517345 Fri Feb 10 2017 4:59pm
Disco_Mikey
I expect you can lift the heads off with the manifolds still attached. But if you have the facilities to lift the body, it's much much easier and quicker to do so Thumbs Up
Post #517363 Fri Feb 10 2017 7:00pm
AnimalMother
Thanks for the info.
Not sure you can remove the heat shields. But it does look like the heads would lift out with the manifolds attached.
Problem now is the bolts on the join to down pipe, one is stuck fast, have tried heat and it's not budging!
Also not sure about getting the timing chain cover off. Looks like will need a puller on the bottom pulley and there's no room.
Will post pictures of valve damage when the heads are off.
Post #517404 Sat Feb 11 2017 11:42am
the wheel arch heatshields can be removed on a diesel.
I doubt they are different on a petrol.
They are in small pieces so will come out.
You need to mark them though, so you know how to refit them. It's a bit of a jigsaw.
Removal is easy though.
Take photos.... every time 1 is removed.
Post #517406 Sat Feb 11 2017 11:56am
AnimalMother
Had a look yesterday and it does look like the heat shield are removable.
But rebuilt the charger instead, here a picture of my shaft:
Post #517619 Mon Feb 13 2017 12:30pm
HemoRRS
Didn't think it was that kind of forum... Whistle
Post #517621 Mon Feb 13 2017 1:01pm
Socast
How long did it take you to get to the charger, nad how did you get the pulley back on ?
I've got a kit to rebuild mine and haven't gotten round to it yet.
EDIT: Oh and when you take the heads off it might be worth replacing the timing chains as thy're meant to be a nightmare to do (and you're half way to doing them anyway).
Post #517670 Mon Feb 13 2017 4:46pm
AnimalMother
Luckily my friendly mechanic removed it, took a while there is one bolt under the charger which is a pita. You need to give yourself a long weekend.
To rebuild the snout didnt take long 3 hours maybe, you need a decent hydraulic press. I found this video and part 2 really useful.
Also, the rebuild kits dont all come with a coupler, make sure you get one of those to.
Post #517738 Tue Feb 14 2017 10:28am
AnimalMother
There is not a lot left of my poor car now.
Post #517739 Tue Feb 14 2017 10:32am
I guess it makes it a lot easier to work on removing the front.
Those bolts can be seized though.
But you have only just started ..... Sad
Post #517751 Tue Feb 14 2017 12:10pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Yes it seems its body off for anything on a Range Rover. WTF is it with that design? I've never heard of another marque that requires body off for anything. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #517903 Wed Feb 15 2017 5:55pm
shepp
Front end is fairly easy to remove, bit of patience and plusgas. I had to remove when changing my condenser on my old 4.2sc
I looked initially at gassing the sc. Like my old 90. I was advised the 4.2 required major head work to make it gas compatible.
 MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #517919 Wed Feb 15 2017 9:05pm
