![]() | Home > Maintenance & Modifications > Do you need lift the body to get heads off 4.2 supercharged |
On a diesel you take the heatshields off inside the wheel arch (what fun!) and then use long extensions to get to the manifold bolts and EGR bolts. |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
Once you have stripped the heads off, please post some pictures, it would be good to see some evidence of the damage that LPG does to these engines. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
I expect you can lift the heads off with the manifolds still attached. But if you have the facilities to lift the body, it's much much easier and quicker to do so |
AnimalMother Member Since: 10 Feb 2017 Location: North Wales Posts: 5 ![]() ![]() ![]() |
Thanks for the info.
the wheel arch heatshields can be removed on a diesel.
Had a look yesterday and it does look like the heat shield are removable.
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
Didn't think it was that kind of forum... ![]() |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
How long did it take you to get to the charger, nad how did you get the pulley back on ?
Luckily my friendly mechanic removed it, took a while there is one bolt under the charger which is a pita. You need to give yourself a long weekend.
There is not a lot left of my poor car now.
I guess it makes it a lot easier to work on removing the front.
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
Yes it seems its body off for anything on a Range Rover. WTF is it with that design? I've never heard of another marque that requires body off for anything. RRS (MY13) Santorini Black SDV6 HSE luxuary
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Front end is fairly easy to remove, bit of patience and plusgas. I had to remove when changing my condenser on my old 4.2sc
Gone 4.2 supercharged RRS Gone 90 Gone s2000 |
