Home > Maintenance & Modifications > Do you need lift the body to get heads off 4.2 supercharged |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
On a diesel you take the heatshields off inside the wheel arch (what fun!) and then use long extensions to get to the manifold bolts and EGR bolts. |
Fri Feb 10 2017 12:10pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
Once you have stripped the heads off, please post some pictures, it would be good to see some evidence of the damage that LPG does to these engines. |
Fri Feb 10 2017 4:59pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
I expect you can lift the heads off with the manifolds still attached. But if you have the facilities to lift the body, it's much much easier and quicker to do so |
Fri Feb 10 2017 7:00pm |
AnimalMother Member Since: 10 Feb 2017 Location: North Wales Posts: 5 |
Thanks for the info.
Sat Feb 11 2017 11:42am |
the wheel arch heatshields can be removed on a diesel.
Sat Feb 11 2017 11:56am |
Had a look yesterday and it does look like the heat shield are removable.
Mon Feb 13 2017 12:30pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Didn't think it was that kind of forum... |
Mon Feb 13 2017 1:01pm |
How long did it take you to get to the charger, nad how did you get the pulley back on ?
Mon Feb 13 2017 4:46pm |
Luckily my friendly mechanic removed it, took a while there is one bolt under the charger which is a pita. You need to give yourself a long weekend.
Tue Feb 14 2017 10:28am |
There is not a lot left of my poor car now.
Tue Feb 14 2017 10:32am |
I guess it makes it a lot easier to work on removing the front.
Tue Feb 14 2017 12:10pm |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
Yes it seems its body off for anything on a Range Rover. WTF is it with that design? I've never heard of another marque that requires body off for anything. RRS (MY13) Santorini Black SDV6 HSE luxuary
Wed Feb 15 2017 5:55pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Front end is fairly easy to remove, bit of patience and plusgas. I had to remove when changing my condenser on my old 4.2sc
Wed Feb 15 2017 9:05pm |
