Home > Off Topic > House Problem - very off topic
Page 3 of 5 <12345>
aljo
Very Annoyed wrote:
Random points.
well that explains it all then Very Happy
Post #51751 Mon Aug 28 2006 9:11pm
Go on then tell me! please! Smile 2005 Zambezi TDV6 - Gone but not forgotten
Post #51752 Mon Aug 28 2006 9:14pm
aljo
your floors Censored ed Very Happy
Post #51753 Mon Aug 28 2006 9:15pm
Banging Head I know! Big Cry Big Cry Big Cry Big Cry 2005 Zambezi TDV6 - Gone but not forgotten
Post #51754 Mon Aug 28 2006 9:17pm
Cliff H
Not good VA Shocked Hope you get it sorted at no expense.
The worst bit will be the disruption that it will cause as this is clearly going to need taking back to the bare bones and starting a fresh.
Good luck mate, if it was the plumbing or the heating I would be able to offer you more advice but it looks like aljo and caz are going to be spot on.
Post #51755 Mon Aug 28 2006 9:25pm
aljo
on a serious note from what i can gather from your information and in my experience is that the sub base underneath your floor slab has not been compacted properly or was put in wet or is generaly infill that we call in the trade " Censored " hence your concrete floor slab is starting to crack (which is also probally a sub standard concrte mix). you will need a structural engineer to find out the extent of damage /movement and will specify a remedy for it ! possibly a complete new floor Shocked its basicly bad workmanship/construction practise and is now down to the nhbc to sort the problem out now as your covered under warranty for structural defects
and we all lived happily ever after Thumbs Up
boobies anyone ? Very Happy
Post #51758 Mon Aug 28 2006 10:22pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Rolling with laughter Rolling with laughter Rolling with laughter
Sorry VA. I know I shouldn't laugh but you fell for that one hook lie and sinker!!!
Hope you get it all sorted soon. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #51761 Mon Aug 28 2006 11:47pm
Sorry to hear this VA... I have come to this thread late and know v little about NHBC claims etc (will leave that to the existing experts here, good work Caz and ) - but if all else fails will your buildings insurance cover the cost of restorative work?
Post #51769 Tue Aug 29 2006 8:44am
noddy and bigears
[quote="aljo"]on a serious note from what i can gather from your information and in my experience is that the sub base underneath your floor slab has not been compacted properly or was put in wet or is generaly infill that we call in the trade " Censored " hence your concrete floor slab is starting to crack (which is also probally a sub standard concrte mix). you will need a structural engineer to find out the extent of damage /movement and will specify a remedy for it ! possibly a complete new floor Shocked its basicly bad workmanship/construction practise and is now down to the nhbc to sort the problem out now as your covered under warranty for structural defect
hold on ..i have heard of this before happening on a block and beam floor as you say the crack are going straight across . if the block and beam floor is layed the same way as the cracks it could be the "bounce " that is in the floor.. i remember this happening on a job i was working on but i can,t remember the remedy as i was doing drainage etc and not involved in removing a new floor Shocked i know that the room had a large span..the buliding contractor is no longer in buisness and i also work for a different co now ..but i will try and find out i still see the old site agent now and again
Post #51859 Tue Aug 29 2006 4:02pm
caz
England 2005 Range Rover Sport Supercharged Java Black
Were there any trees on the site before development? If there were it could have caused 'heave', which might be the cause of the problem with the floor!!!
The foundations would need to have been alot deeper. I don't know if that would happen after 2.5 years though!
Post #51861 Tue Aug 29 2006 4:47pm
aljo
[quote="noddy and bigears
hold on ..i have heard of this before happening on a block and beam floor as you say the crack are going straight across . if the block and beam floor is layed the same way as the cracks it could be the "bounce " that is in the floor.. i remember this happening on a job i was working on but i can,t remember the remedy as i was doing drainage etc and not involved in removing a new floor Shocked i know that the room had a large span..the buliding contractor is no longer in buisness and i also work for a different co now ..but i will try and find out i still see the old site agent now and again[/quote]
i think judging by the pics VA has shown and the random cracks appearing then i would take a wide guess Shocked and say va hasnt got block and beam flooring underneath . i know what your saying about the bounce in block and beam floors but they are pre stressed beams to allow for any substantional movement and normally have a 75 mm/100mm polystyrene insulation and sealed with a 75 mm concrete screed depending on the floor construction specification/building regs at the time
and if VA comes on now and says he has block and beam floors i shall run through the metro centre in gateshead naked Big Cry with a rose shoved up my Censored
Very Happy Very Happy
Post #51863 Tue Aug 29 2006 5:20pm
caz
Oh! Can I sell tickets!!! Wink Wink Wink
Post #51866 Tue Aug 29 2006 5:44pm
God I wish I had block & beam floors but to be honest I don't know. I have been told that a concret pour was involved at some point - if that helps!
Caz there were no trees on the site that needed to be removed.
Again guys thanks! 2005 Zambezi TDV6 - Gone but not forgotten
Post #51869 Tue Aug 29 2006 5:47pm
caz
The concrete pour would be for the foundations. When we built our house we had nine, six metre wagon loads of the stuff. We used bison beams and the floors have never moved.
VA you could always start a new trend, crazy paving for the interior. I know we shouldn't be making light of it, I'd be well upset if I thought my floors had to come up. Evil or Very Mad
Post #51870 Tue Aug 29 2006 5:57pm
aljo
concrete pour saves me a trip to the florist then Very Happy unless it was just the screed on top of the beams Big Cry
caz if you sold tickets Shocked i could be done under the trades description act Wink Wink
Post #51871 Tue Aug 29 2006 5:57pm
Page 3 of 5 <12345>
