Home > Technical > Rattle in 1st - like going over cattle grid
Milblunder
Hi need advise please....day 2 of owning a RRS 2.7 HSE 2007, 85k clear MOT 2 days ago and seems to drive really well except when accelerating in 1st (auto) when I experience a light judder for a second...feels like I'm driving over a cattle grid...any ideas please.....should I be worried as this is my first RR.
Post #516150 Sat Jan 28 2017 10:49pm
DrRob
Not sure but in Berkshire you have a good independent specialist called Rovertune Visitor from fullfatrr.com
Post #516164 Sun Jan 29 2017 8:48am
SRE
Spain
Remember, the Sport does not use first when in Auto, the car stats in 2nd. Thumbs Up
Maybe worth giving one of the Mobile specialists a shout, Have a look for Geoff on the sister site Disco 3/4 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #516173 Sun Jan 29 2017 10:17am
SRE
Spain
This is worth a read
http://www.disco4.com/forum/topic55986.htm...der+in+1st In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #516174 Sun Jan 29 2017 10:20am
Isn't that supercharged models?
I must experiment sometime.
Post #516186 Sun Jan 29 2017 11:21am
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
Per rob, stick it into rovertune. They'll sort it. Do you have a warranty? Could be start of a prop shaft going as is similar to my issues (equally may not be). 2010 TDV8
Post #516221 Sun Jan 29 2017 4:39pm
Jaggs
Mine (2.7 tdv6 ) always sets off in second in auto box , have to use command shift to drop it to 1st Nanocom Evo
Post #516225 Sun Jan 29 2017 4:56pm
Milblunder
As I bought this from a garage who gave me 3 months warranty....should this be something they would cover...it was only a small garage but had good reviews. Would you expect the torque converter or gea box to start going after only 85k (yep I understand it's a RRS and anything can happen!!)....
Post #516233 Sun Jan 29 2017 6:18pm
Jaggs
Yes definitely back to garage irrespective of warranty they should be sorting it out, on a 2007 you need to make sure oil pump was changed same time as cambelt or you could easily be in line for a new engine when it lets go. Nanocom Evo
Post #516234 Sun Jan 29 2017 6:31pm
Milblunder
As I thought....oil pump? I assume that's in the schedule....it's had a 95k service and cambelt changed....
Post #516235 Sun Jan 29 2017 6:39pm
Jaggs
It's not on the service schedule and Landrover don't even acknowledge its an issue but have a read of this vehicle s that have had the cambelt changed but not the oil pump seem to be higher risk
http://www.disco3.co.uk/forum/topic57636.h...lt+failure
The best mod you'll ever do . Nanocom Evo
Post #516241 Sun Jan 29 2017 8:09pm
Socast
My SC usually sets off in first when started in a morning, but if I pull up to lights etc. then it will pull away in second (unless gunned).
Post #516262 Mon Jan 30 2017 9:19am
Lyonhead
Wales
I've had a 2.7 RRS HSE, 2006 and not long after I bought it I heard an unusual sound from what I suspected was the gearbox. More noticeable when travelling with the passenger window down and the noise bouncing off a wall. I took it to the dealership I bought it from, they had it 2 weeks and then had the car returned with a clean bill of health but the noise still there!!!! I also noticed it in a friends 2.7 RRS as well!!!!!! Could it just be a trait of the car especially the 2.7 Diesel Whistle Whistle
It was like a chain dragging along the floor or cattle grid noise but in all gears. Never did get to the bottom of it but did change dealerships with the purchase of my next 3!!!
4.2 sc and 5.0 sc RRS and they both used to start off in second in Auto, you had to pull on the paddle shift to make them start off in 1st. but no repeat of this noise in either of them.
Post #516273 Mon Jan 30 2017 10:49am
Milblunder
Going into the garage Wednesday so let's see what happens....
Post #516277 Mon Jan 30 2017 12:04pm
RichG
Australia 2008 Range Rover Sport TDV6 SE Chawton White
Sounds like the torque converter...
My RRS always starts off in 1st? Have never heard of them starting in 2nd... MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
2001 Audi A4 1.8T quattro 5mt sport, 340k km
1990 Nissan Pintara TRX, lots of mods, 438k km
Post #516338 Mon Jan 30 2017 9:26pm
