Home > Technical > Rattle in 1st - like going over cattle grid |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Not sure but in Berkshire you have a good independent specialist called Rovertune Visitor from fullfatrr.com
Sun Jan 29 2017 8:48am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Remember, the Sport does not use first when in Auto, the car stats in 2nd.
Sun Jan 29 2017 10:17am |
This is worth a read
Sun Jan 29 2017 10:20am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
Isn't that supercharged models? I must experiment sometime. |
Sun Jan 29 2017 11:21am |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
Per rob, stick it into rovertune. They'll sort it. Do you have a warranty? Could be start of a prop shaft going as is similar to my issues (equally may not be). 2010 TDV8 |
Sun Jan 29 2017 4:39pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
Mine (2.7 tdv6 ) always sets off in second in auto box , have to use command shift to drop it to 1st Nanocom Evo |
Sun Jan 29 2017 4:56pm |
Milblunder Member Since: 28 Jan 2017 Location: Berkshire Posts: 24 |
As I bought this from a garage who gave me 3 months warranty....should this be something they would cover...it was only a small garage but had good reviews. Would you expect the torque converter or gea box to start going after only 85k (yep I understand it's a RRS and anything can happen!!).... |
Sun Jan 29 2017 6:18pm |
Yes definitely back to garage irrespective of warranty they should be sorting it out, on a 2007 you need to make sure oil pump was changed same time as cambelt or you could easily be in line for a new engine when it lets go. Nanocom Evo |
Sun Jan 29 2017 6:31pm |
As I thought....oil pump? I assume that's in the schedule....it's had a 95k service and cambelt changed.... |
Sun Jan 29 2017 6:39pm |
It's not on the service schedule and Landrover don't even acknowledge its an issue but have a read of this vehicle s that have had the cambelt changed but not the oil pump seem to be higher risk
Sun Jan 29 2017 8:09pm |
My SC usually sets off in first when started in a morning, but if I pull up to lights etc. then it will pull away in second (unless gunned). |
Mon Jan 30 2017 9:19am |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 |
I've had a 2.7 RRS HSE, 2006 and not long after I bought it I heard an unusual sound from what I suspected was the gearbox. More noticeable when travelling with the passenger window down and the noise bouncing off a wall. I took it to the dealership I bought it from, they had it 2 weeks and then had the car returned with a clean bill of health but the noise still there!!!! I also noticed it in a friends 2.7 RRS as well!!!!!! Could it just be a trait of the car especially the 2.7 Diesel
Mon Jan 30 2017 10:49am |
Going into the garage Wednesday so let's see what happens.... |
Mon Jan 30 2017 12:04pm |
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 |
Sounds like the torque converter...
Mon Jan 30 2017 9:26pm |
