Home > Maintenance & Modifications > Battery Charge level |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
11.47V is only about 20% charged. I would get hold of a good quality smart charger and give the battery a full charge.
Wed Jan 04 2017 7:49pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Crikey. only 20%, that isn't good.
Thu Jan 05 2017 6:40am |
Sun Jan 22 2017 1:59pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
Can't see what you mean.
Sun Jan 22 2017 2:14pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
If its a Trickle Charger, then connect it onto the Battery In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Jan 22 2017 2:29pm |
That's what i thought, if i'm trickle charging the battery, nightly, or weekly surely it connects to the batteries positive and negative terminals. but the manual said positive to battery, negative to earth on chassis, also did soem google searches and it was 50/50 split.
Sun Jan 22 2017 2:32pm |
I use to leave my 2008 Sport on for weeks connected direct to the Battery In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Jan 22 2017 2:36pm |
I think they worry about sparking near the battery (which CTEK's don't do)
Sun Jan 22 2017 2:43pm |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 |
I have my quick connector under the battery cover and not had any problems.
Sun Jan 22 2017 2:52pm |
