Home > Maintenance & Modifications > Battery Charge level
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
What kind of reading should i be getting from a battery in the car (probably the original ; 2006 model) when the car has been stood unused for a couple of days.
Outside temperature was around -1 to 4 degrees. With the tool i had it was measuring 11.47 volts? Is that normal?
I've read elsewhere that a poor battery can also throw up the suspension faults, which i get intermittently.
cheers 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #513541 Wed Jan 04 2017 2:44pm
11.47V is only about 20% charged. I would get hold of a good quality smart charger and give the battery a full charge.
Around 12.7V is fully charged. 2012 SDV6 - it's missing a couple of cylinders
Post #513575 Wed Jan 04 2017 7:49pm
Pakolainen
Crikey. only 20%, that isn't good.
Will get it charged asap. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #513606 Thu Jan 05 2017 6:40am
Pakolainen
i went and bought a trickle charger as i don't want to be having battery issues constantly and it seems most people on here recommend them.
just been to install it and the manual says one eyelet over the positive and one earthed on the chassis.
I didn't see anything nearby that looked like an earth. would this be suitable?
Also, it has the quick connector, would i be able to leave the quick connector connected and replace the plastci housing over the battery and fusebox? Or does anyone perceive issues with that?
cheers
Steve 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #515434 Sun Jan 22 2017 1:59pm
Can't see what you mean.
There are 3 earth studs on the wing just the other side of the plastic wall.
[URL=]
[/URL]
LHD different I guess?
If you would prefer a hook up in the boot see another thread..
http://www.rrsport.co.uk/forum/topic46559.html
Post #515439 Sun Jan 22 2017 2:14pm
SRE
Spain
If its a Trickle Charger, then connect it onto the Battery In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #515444 Sun Jan 22 2017 2:29pm
Pakolainen
That's what i thought, if i'm trickle charging the battery, nightly, or weekly surely it connects to the batteries positive and negative terminals. but the manual said positive to battery, negative to earth on chassis, also did soem google searches and it was 50/50 split.
cheers
Mazda 3 1.6 2010
Post #515445 Sun Jan 22 2017 2:32pm
SRE
Spain
I use to leave my 2008 Sport on for weeks connected direct to the Battery Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #515448 Sun Jan 22 2017 2:36pm
I think they worry about sparking near the battery (which CTEK's don't do)
So they like to be away from the battery.
I don't think its very easy to put an eyelet on a RRS earth terminal anyway?
Post #515450 Sun Jan 22 2017 2:43pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I have my quick connector under the battery cover and not had any problems.
Mine is the Ctek.
I was advised by the main dealer not to connect the negative directly to the battery and to use an earth point on the body. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #515452 Sun Jan 22 2017 2:52pm
