![]() | Home > General (L494) > MY17 order - Very High Spec HSE v HSE Dynamic v Autobigraphy |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
I am all for the pan roof with tilt and slide definitely brightens up the inside of the cabin.
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
The cheaper HSE I spec'd up includes
kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 ![]() |
Given nearly all of your options are standard on the Autobiography Dynamic, how far away is your final HSED price to the base price of the Autobiography Dynamic with the same engine?
Fixed panoramic roof actually lets in more light and the climate control is well able to cope with the glass area. I would certainly spec the heated steering wheel and upgrade to the 825w audio as what you get now in the HSE is utter crap compared to what I have in my 2015MY which is the Meridian 380w system that was then standard. If you want a bit of external bling then the ride on 22" wheels is very very good.
Believe it or not but the difference in price between an HSE with this spec amd an AB is �10k |
Which engine?
It is yes, as once I hit the Dynamic I'm ltd to budget so have to lose some options...where as with the HSE I can spec up the options and still be cheaper than a Dynamic - hence my question |
I've plugged your specs into the config and then asked for finance quotes on each (based on it being a V6D engine). The finance quotes will show what the minimum value your car will be in 3yrs time. This is a yardstick for you to weight up the spend of options.
This is very interesting, thanks! Let me get on the phone to LRPR...... |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
A minor point, but one which may make you lean towards an AB, is that the extended leather doesn't include the colour-coded steering wheel pad nor is it the upgraded type of leather that you get in an AB. The colour of the steering wheel may be noticeable (and possibly annoying) depending on your interior colour choices. |
The only caveat I will make is the 'total amount payable' will be more over the total term on a more expensive list price car, because interest payments will be higher on the GFV/RV, however that's only relevant if you plan to pay the balloon at the end and keep the car (which I assume you won't, you'll trade in for another) because if you plan to trade out of the agreement early then interest is refunded in the settlement figure, and the balloon is irrelevant if you don't plan to pay it. Play around with some scenarios and see what suits. Rule of thumb is for every �1000 in/out (whether that be discount/options/deposit/RV etc) equates to a �30 - or + to the PCP amount each month. SOLD - MY16 SDV6 Autobiography Dynamic - Fire Engine Red, Fixed contrast pan roof, TV, Dual Screen, 5+2, Privacy, Noble paddles. |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
I went through a similar process when I ordered mine late last year. Logic would say to buy the low option higher grade model, in my case, SE vs HSE both SDV6 with low range and terrain 2. I actually originally ordered the HSE upon advice from others...but it just didn't sit well with me. Basically, I was putting on a very similar suite of options on both grade cars. Many upgrades on the HSE were not of value to me (bigger wheels, memory seats)so it just didn't add up, for me. Bottom line, still more that 10k being the difference in Australia. Even if you have finance with or without a balloon payment, you still pay interest on the total amount for the time you have that debt.
Caerketton Member Since: 23 Aug 2014 Location: East Lothian Posts: 21 ![]() ![]() |
I went through the same process and ordered an AB which will arrive shortly |
I'm also AB positive! |
