Home > General (L494) > What is inside the headlamp led "oval"?
Clock
Just ordered a HSE after reading every review & forum post etc.
I cannot find what is inside the oval led ring on the front headlamps, does anyone know?
Post #513188 Fri Dec 30 2016 11:46am
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Main beam spotlight.....
I think that is what you are referring to. 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #513194 Fri Dec 30 2016 4:17pm
Clock
Thanks for the info.
I had read somewhere that main and dipped beams used a mechanical flap over the Xenon (which I assume is the 'projector' style lens). So then assumed the oval part was just styling or something to do with the adaptive or high beam assist.
Post #513195 Fri Dec 30 2016 4:47pm
Tim in Scotland
I think it is just styling, to give the distinctive DRL L.E.D 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #513200 Fri Dec 30 2016 5:52pm
Renaco
No, those are housing the "corner" light spots, below 30 km/h when cornering those are working, if you have adaptive headlights!
Post #513213 Fri Dec 30 2016 7:18pm
wilf
Nothing inside those ovals at all apart from some reflective "headlamp jewellry" on mine, which has adaptive bi Xenons.
Dip/main beam is done via a mechanical shutter, cornering lamps are on the outer edge of the headlamp assembly. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #513280 Sun Jan 01 2017 8:36am
Renaco
No, the cornering lights are in the oval! Wink
Take your car in front of a window and put the gear in "d", then have a look once you turn your steering wheel... Wink
There are two led's placed on top of the inner oval, invisible as you see only the reflectors.
Post #513283 Sun Jan 01 2017 10:45am
wilf
They absolutely are not in that oval on my car, and yes I have double checked. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #513288 Sun Jan 01 2017 11:59am
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
Has two LEDs facing down, for corner lighting and also for Flashing, based on the size they looks like 1 or 3w LEDs.
Please see the phot below, LEDs are not very clear so I circled them in red.
Post #513293 Sun Jan 01 2017 1:34pm
Renaco
Maybe this underlines it:
Sorry, took the pictures at a VW Garage, some strange mirror effects... Wink
Here the LED's
Here straight
Here cornering
Post #513295 Sun Jan 01 2017 1:57pm
Clock
I think Renaco's answer is correct, I have just found the description on the configurator and it says they are static bending lamps to light the kerbside area in tight bends (with the ADAPTIVE XENON HEADLIGHTS options).
Thanks for the help.
Post #513296 Sun Jan 01 2017 2:11pm
SDV6RRS
100% they are the cornering lights. I think you get them regardless of adaptive headlights. My adaptive headlights swivel as I turn gentle corners, but those oval cornering lights come on on sharp'ish bends as well. It's very noticeable.
A lot of other manufacturers seem to use the fog lights as the extra cornering lights. Personally I would have preferred even more full beam power rather than those.
Qudos to Renaco for managing to take a picture! 2014 MY RRS HSE Dynamic
2000 Porsche Boxster S
2004 BMW X5 (Gone)
Post #513315 Sun Jan 01 2017 8:13pm
wilf
Never let it be said that I don't admit when I am wrong. So:
I WAS WRONG!
I looked and I looked but I could not see those LEDs at the top of the Oval, but since so many of you were emphatic otherwise, I knew I had to investigate further, and I tried starting the car up and turning on the lights last night and turning the steering wheel, but of course as you open the door the lights go out! So I couldn't prove it one way or another last night.
And so it was this morning, as I pulled up at work for the first working day of 2017, that I looked into the reflection from a window I deliberately parked facing, and Voilá! The static corning lights are indeed inside that oval.
You guys were right. Apologies. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #513404 Tue Jan 03 2017 7:32am
PetesRRS
Australia 2013 Range Rover Sport SDV6 HSE Fuji White
Same. But also find they come on when passing very close to an object. When I drive out of my driveway I pass very close to a brick wall and I find the right side lamp turns on and lights up the wall then turns off when passed.
Post #513496 Wed Jan 04 2017 6:18am
midsman
I believe that only cars with adaptive xenon headlights have these little led cornering lights fitted. My car certainly has not got them fitted and I do not have adaptive headlights. So if you have adaptive headlights you have them, if not stop looking., they are not there.
Speaking to LR today I was informed that the oval shape with forms part of the DRL is a Land Rover signature light ( same as Audi have one that is easily recognisable), so that a LR product can easily be spotted on the road. Perhaps this is for motorists who cannot see such a big chunk of metal travelling on the highway.
Had 4 upgrades on the car today, including one that required both keys to be with the car. 2015 Range Rover Sport Autobiography Dynamic SDV6
2012 Range Rover Sport SDV6 HSE Luxury- Santori Black with Autobiography Ebony/ Ivory interior- SOLD
Post #513545 Wed Jan 04 2017 4:30pm
