![]() | Home > Technical > Crack in dashboard around passenger airbag |
A cosmetic issue - only realistic fix is to replace the entire dash top. 07MY RRS TDV6
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Ouch. That is guaranteed to not be a cheap job.
But a dash mat over the dash top - they look OK and will hide the crack. You obviously have the opposite issue I have in Australia where it is high UV and very high internal temps crack the dash where I guess in winter you have the opposite very cold temps making the dash material brittle causing the cracks. 07MY RRS TDV6
Good tip. thanks. Yes, usually it would be extreme cold and hot int he summer although so far we've had a brief spell of -20 and as that breezed by we're now up to +4. There's more snow in the sahara than in Finland (southern) right now.
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 ![]() ![]() ![]() |
Has yours cracked Garry?
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Garry,
My dash has not cracked but the square bit in the centre up near the windscreen that has the sensor dome in it has but is not an issue.
The Aspen interior is still lovely to look at even after all these years................ My 1st RRS had exactly the same parchment and Aspen interior. Mine had the Light Cherrywood hockey sticks and door trim, pity is wasn't more popular (or maybe not so unfortunate!) My exterior colour was also one of the less common shades like your Arctic Frost - mine was Giverny Green
Yes - Aspen is pleasant on the eye but the cream gets dirty very quick and is hard to clean but has worn well even with a lot of scrubbing. 07MY RRS TDV6
Thanks Garry,
A quick google of RRS dash cover site:au threw up this http://www.customcarmats.com.au/range-rove...7_845.html 07MY RRS TDV6
Thanks,
Yeah, tried ebay and came up with them straight away $60 posted from W.A. 3 colors black, charcol and brown.
Garry,
