Home > Technical > Crack in dashboard around passenger airbag
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Jumped out of the car today and noticed on the passenger side (right hand side) the corner around the bottom right of the air bag seems to show a visible crack from the rest of the dashboard.
Is this something to worry about? Potential fixes?
Thanks 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #512702 Wed Dec 21 2016 6:39am
garrycol
Australia
A cosmetic issue - only realistic fix is to replace the entire dash top. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #512704 Wed Dec 21 2016 7:50am
Pakolainen
Ouch. That is guaranteed to not be a cheap job.
Cosmetically it will stay as it is then.
thanks 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #512727 Wed Dec 21 2016 1:16pm
garrycol
Australia
But a dash mat over the dash top - they look OK and will hide the crack. You obviously have the opposite issue I have in Australia where it is high UV and very high internal temps crack the dash where I guess in winter you have the opposite very cold temps making the dash material brittle causing the cracks. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #512765 Thu Dec 22 2016 1:11am
Pakolainen
Good tip. thanks. Yes, usually it would be extreme cold and hot int he summer although so far we've had a brief spell of -20 and as that breezed by we're now up to +4. There's more snow in the sahara than in Finland (southern) right now.
cheers
Steve 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #512767 Thu Dec 22 2016 6:31am
RichG
Australia 2008 Range Rover Sport TDV6 SE Chawton White
Has yours cracked Garry?
Mine hasn't yet, but for the last year I have been able to see the outline of the airbag as a slight indentation in the dash. My driver's airbag cover has also warped upwards a bit, which I know they all do eventually.
I use one of those reflective sun shields in the windscreen if I'm parking for more than a couple of hours. On a hot day, the dash is too hot to touch without it. I'm hoping that will save it for a bit longer, then it will be a dashmat I guess.
My mate's 05 Toyota Prado has the worst dash I've ever seen. Spider web of cracks all through it!
In contrast my Audi A4, which I hardly even bother using a sun shield in and is 7 years older than the RRS, dash looks perfect still... MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
2001 Audi A4 1.8T quattro 5mt sport, 340k km
1990 Nissan Pintara TRX, lots of mods, 438k km
Post #512847 Fri Dec 23 2016 12:09am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Garry,
I have a crack in my dashtop. I have been interested in a dash mat for the same reasons you have pointed out.
Do LR have one ? or does anyone know what else might fit??? 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #512854 Fri Dec 23 2016 9:33am
garrycol
Australia
My dash has not cracked but the square bit in the centre up near the windscreen that has the sensor dome in it has but is not an issue.
I have had a dash mat for just under 6 years - bought on ebay, fits well, has not faded and looks great,
 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #512863 Fri Dec 23 2016 12:13pm
Tim in Scotland
The Aspen interior is still lovely to look at even after all these years................ My 1st RRS had exactly the same parchment and Aspen interior. Mine had the Light Cherrywood hockey sticks and door trim, pity is wasn't more popular (or maybe not so unfortunate!) My exterior colour was also one of the less common shades like your Arctic Frost - mine was Giverny Green
[URL=]
[/URL]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512866 Fri Dec 23 2016 3:50pm
garrycol
Australia
Yes - Aspen is pleasant on the eye but the cream gets dirty very quick and is hard to clean but has worn well even with a lot of scrubbing. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #512878 Sat Dec 24 2016 2:01am
CRACKA
Thanks Garry,
I will check out e-bay to see if they are still around.
I did go to several Auto stores, but no luck not even order in. Although I did see a VE Commodore parked at one and the dash seemed similiar. So being forward ,inside the store I asked could I try one. (This is before your post).
If anyone can't get the real thing one of these will do the trick. Its not quite as long but that allows the side vents not to be covered up. It was one from Supercheap and came with positioning tape which will hold it in place okay. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #512927 Sat Dec 24 2016 7:45pm
garrycol
Australia
A quick google of RRS dash cover site:au threw up this http://www.customcarmats.com.au/range-rove...7_845.html 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #512938 Sun Dec 25 2016 12:01am
Pakolainen
Thanks,
need to find LHD. but i'll leave that for another day, need to do my bonnet lettering first, which apparently can only be done in 20 degrees or warmer. and i'm in finland where it's only 0 degrees at the moment 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #512944 Sun Dec 25 2016 9:36am
CRACKA
Yeah, tried ebay and came up with them straight away $60 posted from W.A. 3 colors black, charcol and brown.
I did see some LHD ones as well. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #512947 Sun Dec 25 2016 10:25am
CRACKA
Garry,
I got the ebay one delivered the other day. Question is it has slits for the air bag release but whats the story with the 'sensor' dome in the middle of the dash. Question 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #514420 Sat Jan 14 2017 6:03am
