Home > Technical > Crack in dashboard around passenger airbag |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
A cosmetic issue - only realistic fix is to replace the entire dash top. 07MY RRS TDV6
Wed Dec 21 2016 7:50am |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Ouch. That is guaranteed to not be a cheap job.
Wed Dec 21 2016 1:16pm |
But a dash mat over the dash top - they look OK and will hide the crack. You obviously have the opposite issue I have in Australia where it is high UV and very high internal temps crack the dash where I guess in winter you have the opposite very cold temps making the dash material brittle causing the cracks. 07MY RRS TDV6
Thu Dec 22 2016 1:11am |
Good tip. thanks. Yes, usually it would be extreme cold and hot int he summer although so far we've had a brief spell of -20 and as that breezed by we're now up to +4. There's more snow in the sahara than in Finland (southern) right now.
Thu Dec 22 2016 6:31am |
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 |
Has yours cracked Garry?
Fri Dec 23 2016 12:09am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Garry,
Fri Dec 23 2016 9:33am |
My dash has not cracked but the square bit in the centre up near the windscreen that has the sensor dome in it has but is not an issue.
Fri Dec 23 2016 12:13pm |
The Aspen interior is still lovely to look at even after all these years................ My 1st RRS had exactly the same parchment and Aspen interior. Mine had the Light Cherrywood hockey sticks and door trim, pity is wasn't more popular (or maybe not so unfortunate!) My exterior colour was also one of the less common shades like your Arctic Frost - mine was Giverny Green
Fri Dec 23 2016 3:50pm |
Yes - Aspen is pleasant on the eye but the cream gets dirty very quick and is hard to clean but has worn well even with a lot of scrubbing. 07MY RRS TDV6
Sat Dec 24 2016 2:01am |
Thanks Garry,
Sat Dec 24 2016 7:45pm |
A quick google of RRS dash cover site:au threw up this http://www.customcarmats.com.au/range-rove...7_845.html 07MY RRS TDV6
Sun Dec 25 2016 12:01am |
Thanks,
Sun Dec 25 2016 9:36am |
Yeah, tried ebay and came up with them straight away $60 posted from W.A. 3 colors black, charcol and brown.
Sun Dec 25 2016 10:25am |
Garry,
Sat Jan 14 2017 6:03am |
