Home > Technical > Help please pulling my hair out
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
On my 55 plate sport the radio keeps going off no sound I get park brake fault sometimes in the screen I have had it read no faults stored I don't have a problem with the park brake all works fine I have replaced the brake light switch and the battery was replaced 4 months ago
Can anyone help oh and now and again the sat nav screen goes back to the logo then returns to normal
Thx in advance "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #511505 Sun Dec 04 2016 11:42am
Plazmapete
When does it happen? Within first couple of minutes after starting???
Post #511508 Sun Dec 04 2016 12:03pm
HemoRRS
Check that the region is set to UK and not defaulted to Belgium as this can cause similar problems.
Post #511511 Sun Dec 04 2016 12:21pm
madmackie
It's seems to be when the when the car is cold but has got worse "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #511513 Sun Dec 04 2016 12:42pm
Plazmapete
Mine does the same. If you either press the program button of the heated screen or turn them on one by one it stops and radio and satnav work fine. After a couple of mins you can turn them off and it will work fine. Hope it helps.
Post #511517 Sun Dec 04 2016 1:36pm
erickwan
Malaysia
Had kind of similar symptoms before and a new battery cured all.
Post #511521 Sun Dec 04 2016 3:13pm
madmackie
I have noticed the display on the dashboard flickering also
When I put heated screen on it curiously seems to be better "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #511535 Sun Dec 04 2016 4:35pm
Plazmapete
Strange things these cars are.
Post #511537 Sun Dec 04 2016 4:49pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, alternator on the way out ?? i had this untill the alternator was replaced, now all fine Thumbs Up  2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #511550 Sun Dec 04 2016 7:02pm
shakeapaw
New alternator and a new decent battery 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #511811 Thu Dec 08 2016 10:34am
madmackie
hi all an update battery is a bosch so its decent and only 4 months old mick (shakeapaw) checked charge voltage its fluctuating between 15.2 upto 16.8 then jumps to 18 so I guess the alternator is f***** over charging more money to spend just when you don't need it and to top it off a ball joint has gone Sad "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #511853 Thu Dec 08 2016 6:42pm
Gornal Hills
Hi, these creatures are very fussy about the volts they munch on, and if it's not right they will definitely play up... i know this from experience Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #511857 Thu Dec 08 2016 6:55pm
shakeapaw
I appreciate your battery is only 4 months old, however it has been recieving anything upto 18 volts, so is already on the knackered road. I hope you get away with it, however be prepared to buy another, or take yours back as faulty 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #511866 Thu Dec 08 2016 8:43pm
madmackie
hi shakeapaw ive bought one anyway just to be safe thx pal just a querie you know my car it doesn't have dsc and acc does it thx "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #511914 Fri Dec 09 2016 4:53pm
Tim in Scotland
It will have DSC as all RRS's had it (IIRC it is a requirement after 2000 for all cars to have it). The option you might want to know if your car has is Dynamic Response - this is the trick rear suspension and uprated sterring rack with 20" wheels. Visually there are no indications externally but under the bonnet you will have as additional hydraulic fluid rank cover as the system was electro hydraulic. In 2005 diesels could not be specced from the factory with wheels bigger than 19" unless the heavy duty steering rack that was standard on the V8 Petrols was specced. You could still fit 20" wheels but LR would immediately invalidate the warranty on the steering and transmission.................. after 2007 the uprated rack was made standard on all RRS's
ACC doubtful as in 2005 only the petrol engined RRS's got it and it wasn't even an option on diesels until the TDV8 was launched. You will know if you have acc as in the lower intake, passenger side there is a black plastic fronted detector unit see the photo below
 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #511915 Fri Dec 09 2016 5:17pm
