Home > Technical > Help please pulling my hair out |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 |
On my 55 plate sport the radio keeps going off no sound I get park brake fault sometimes in the screen I have had it read no faults stored I don't have a problem with the park brake all works fine I have replaced the brake light switch and the battery was replaced 4 months ago
Sun Dec 04 2016 11:42am |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
When does it happen? Within first couple of minutes after starting??? |
Sun Dec 04 2016 12:03pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Check that the region is set to UK and not defaulted to Belgium as this can cause similar problems. |
Sun Dec 04 2016 12:21pm |
It's seems to be when the when the car is cold but has got worse "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
Sun Dec 04 2016 12:42pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
Had kind of similar symptoms before and a new battery cured all. |
Sun Dec 04 2016 3:13pm |
I have noticed the display on the dashboard flickering also
Sun Dec 04 2016 4:35pm |
Strange things these cars are. |
Sun Dec 04 2016 4:49pm |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, alternator on the way out ?? i had this untill the alternator was replaced, now all fine 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Dec 04 2016 7:02pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
New alternator and a new decent battery 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Thu Dec 08 2016 10:34am |
hi all an update battery is a bosch so its decent and only 4 months old mick (shakeapaw) checked charge voltage its fluctuating between 15.2 upto 16.8 then jumps to 18 so I guess the alternator is f***** over charging more money to spend just when you don't need it and to top it off a ball joint has gone "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
Thu Dec 08 2016 6:42pm |
Hi, these creatures are very fussy about the volts they munch on, and if it's not right they will definitely play up... i know this from experience 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Thu Dec 08 2016 6:55pm |
I appreciate your battery is only 4 months old, however it has been recieving anything upto 18 volts, so is already on the knackered road. I hope you get away with it, however be prepared to buy another, or take yours back as faulty 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Thu Dec 08 2016 8:43pm |
hi shakeapaw ive bought one anyway just to be safe thx pal just a querie you know my car it doesn't have dsc and acc does it thx "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
Fri Dec 09 2016 4:53pm |
It will have DSC as all RRS's had it (IIRC it is a requirement after 2000 for all cars to have it). The option you might want to know if your car has is Dynamic Response - this is the trick rear suspension and uprated sterring rack with 20" wheels. Visually there are no indications externally but under the bonnet you will have as additional hydraulic fluid rank cover as the system was electro hydraulic. In 2005 diesels could not be specced from the factory with wheels bigger than 19" unless the heavy duty steering rack that was standard on the V8 Petrols was specced. You could still fit 20" wheels but LR would immediately invalidate the warranty on the steering and transmission.................. after 2007 the uprated rack was made standard on all RRS's
Fri Dec 09 2016 5:17pm |
