Home > Faults & Fixes > Dreaded suspension fault, what's best? |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Ok on my road trip to London today, no warning just yellow light comes up on the dashboard a little tone and the warning normal ride height only suspension fault.
Thu Sep 15 2016 8:53pm |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
I have just had the same light on, and a noisy compressor sound.
Thu Sep 15 2016 9:45pm |
Thanks for them, Think I'm going to just replace the cap for now, I can't hear my compressor, well it's definately not abnormal sounding if that makes sense, plus I havnt got a jack yet so I could just about get underneath it to get the cover off. Although the single 10mm bolt snapped straight off, the 2 others Ho,ding the cover on we're t30 torx so a good soak in wd40 and they came out easy as pie. Nope changed my mind, just ordered a complete rebuild kit, looks simple enough. Just need to try borrow a jack now.lol Last edited by Danv8 on Fri Sep 16 2016 10:08am. Edited 1 time in total |
Fri Sep 16 2016 8:57am |
Just a quick one though if I remove the cap will my suspension drop if it's set at off road height?
Fri Sep 16 2016 8:59am |
Wow that was quick ordered the rebuild kit from x8r at 11am yesterday and kit arrived this morning, also ordered the replacement captive nuts rom eBay and they are now in my possession. Just got to wait for my jack now...
Sat Sep 17 2016 10:56am |
Please ensure it's a good jack and use axle stands to, don't rely on the jack on its own. The jack must be a minimum 3 Ton capability one to lift vehicle safely. Use the blocks each side of wheel other corner to ensure it won't roll (normally part of tool kit in boot section under floor.) John
Sun Sep 18 2016 12:06am |
Got this lot on the way
Sun Sep 18 2016 7:13am |
Well jack arrived today, and so I set to work removing the compressor, I persevered and removed all the airlines with out the need to cut and add connectors, just took a wee bit of wd40 and patience. Fitted the replacement filters, granuals and cap easily but trying to match up the o rings, all I can guess is I got sent the wrong ones as not one matched! They were either too big too small or to thin! So I ended up just replacing the piston seal liner and chamber gasket, and gave up with o rings. I did try contacting them but with time not on my side I just had to get it back together and on the car.
Mon Sep 19 2016 7:15pm |
Coxylad Member Since: 11 Jul 2013 Location: Preston Posts: 48 |
Hi all
Tue Sep 20 2016 1:36am |
skilachi Member Since: 31 Oct 2013 Location: London Posts: 55 |
Hi guys,
Fri Dec 02 2016 7:18pm |
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90 |
when the suspension fails can you safely drive home with the cat so low |
Fri Dec 02 2016 7:40pm |
Hi steve,
Fri Dec 02 2016 8:48pm |
Hi, just got your pm and have sent the links from where I got the above kits, yours looks like far worse than mine, I just had the light come on, first I would get someone to try raise and lower it and you listen to hear if your compressor is actually working, if not check fuses etc otherwise it then may be a case of a new or replacement motor or complete unit. If it is working, then ide follow the pipes incase one has split, again it's a case for listening for air leaks or use a high soapy solution and mist it over the pipes, any leaks will cause bubbles.
Sun Dec 04 2016 1:02pm |
