Home > Faults & Fixes > Dreaded suspension fault, what's best?
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Ok on my road trip to London today, no warning just yellow light comes up on the dashboard a little tone and the warning normal ride height only suspension fault.
Now I've read the faults and fixes so I'm hoping it's the compressor cap that's cracked. So is it best to just change the cap and o ring, or a complete kit with new filters and drying granuals.
So either
http://www.ebay.co.uk/itm/Land-Rover-Disco...SwuTxV9BN-
Or
http://www.ebay.co.uk/itm/171694006022?_tr...EBIDX%3AIT
Post #505543 Thu Sep 15 2016 9:53pm
adameverett
I have just had the same light on, and a noisy compressor sound.
So taking a punt on the DIY refurb vs new unit. The kit I have opted for £69
http://www.ebay.co.uk/itm/121722499240
Contains the piston ring sets, if your taking it off might as well hedge overhaul the unit.
Don't forget captive nuts, probably rusted. £4
http://www.ebay.co.uk/itm/122098077362
50/50 chance I am told the pipes don't come out the compressor so need cutting off, thats another £30 kit,
http://www.ebay.co.uk/itm/Range-Rover-Spor...2214000106
Planning to have a go this weekend!
Post #505556 Thu Sep 15 2016 10:45pm
Danv8
Just had the cover off and bingo
[URL=]
[/URL]
Post #505578 Fri Sep 16 2016 9:50am
Danv8
Thanks for them, Think I'm going to just replace the cap for now, I can't hear my compressor, well it's definately not abnormal sounding if that makes sense, plus I havnt got a jack yet so I could just about get underneath it to get the cover off. Although the single 10mm bolt snapped straight off, the 2 others Ho,ding the cover on we're t30 torx so a good soak in wd40 and they came out easy as pie.
Nope changed my mind, just ordered a complete rebuild kit, looks simple enough. Just need to try borrow a jack now.lol
Post #505579 Fri Sep 16 2016 9:57am
Danv8
Just a quick one though if I remove the cap will my suspension drop if it's set at off road height?
Found out, nope it won't due to inline 1 way valves.
Post #505580 Fri Sep 16 2016 9:59am
Danv8
Wow that was quick ordered the rebuild kit from x8r at 11am yesterday and kit arrived this morning, also ordered the replacement captive nuts rom eBay and they are now in my possession. Just got to wait for my jack now...
[URL=]
[/URL]
Post #505688 Sat Sep 17 2016 11:56am
Johnski
Please ensure it's a good jack and use axle stands to, don't rely on the jack on its own. The jack must be a minimum 3 Ton capability one to lift vehicle safely. Use the blocks each side of wheel other corner to ensure it won't roll (normally part of tool kit in boot section under floor.) Smile John
Post #505718 Sun Sep 18 2016 1:06am
Danv8
Got this lot on the way
http://www.sgs-engineering.com/garage-equi...xle-stands
Post #505727 Sun Sep 18 2016 8:13am
Danv8
Well jack arrived today, and so I set to work removing the compressor, I persevered and removed all the airlines with out the need to cut and add connectors, just took a wee bit of wd40 and patience. Fitted the replacement filters, granuals and cap easily but trying to match up the o rings, all I can guess is I got sent the wrong ones as not one matched! They were either too big too small or to thin! So I ended up just replacing the piston seal liner and chamber gasket, and gave up with o rings. I did try contacting them but with time not on my side I just had to get it back together and on the car.
[URL=]
[/URL]
The crack
[URL=]
[/URL]
[URL=]
[/URL]
All wrong sizes!
[URL=]
[/URL]
Anyways it's all back together, nice and quiet fully functioning and no error messages. So I'm one happy chappy once more.
Also re aligned the red cover of my side step, noticed it had dropped due to a few missing an corroded rivets. So all lined up and fastened again.
Post #505865 Mon Sep 19 2016 8:15pm
Coxylad
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi all
I had the suspension problem normal ride hight and the yellow light on Dash
RRS 2,7 tdv6 2007
It was an Hitachi
I ordered a repair kit £86 but have found them for £56 now
I stripped the old one out and refurbished it put it back on and works perfect
Really happy as it just cost me £86 instead of around £500 i thing the new ones are AMK
been on for around 12 days now, I use my car every day for pottering around with no issues,
RESULT 2007 RANGE ROVER SPORT 2.7 TDV6 HSE in silver
Post #505888 Tue Sep 20 2016 2:36am
skilachi
Hi guys,
can you please PM with the link on where to get this. Think my suspension has given way this morning. The rear back suspension lowered as i was driving with the warning suspension lights coming on....now the rear back suspension will not raise. The front ones looks to be in the normal position but looks like the compressor is dead is its not working when i press normal/lower/off-road mode.
I've used one of those icarsoft LR II diagnostic tools and got this showing
C1A20
Pressure increases too slow when filling reservoir
Found similar repair kit but the guy no longer sells them.
http://www.rrsport.co.uk/forum/topic38956....sion+fault
thanks
Range Rover Sports 2005
Post #511397 Fri Dec 02 2016 8:18pm
steve.rrs
when the suspension fails can you safely drive home with the cat so low
Post #511399 Fri Dec 02 2016 8:40pm
skilachi
Hi steve,
I didn't want to risk it Luckily I was looking for parking in an off-street. So I just parked it and called AA to come and recover with a flatbed truck back home.
It surely can drive but I could feel it dragging at the back and something was wrong.....that was how i got to know about the rear lowered down.
Post #511405 Fri Dec 02 2016 9:48pm
Danv8
Hi, just got your pm and have sent the links from where I got the above kits, yours looks like far worse than mine, I just had the light come on, first I would get someone to try raise and lower it and you listen to hear if your compressor is actually working, if not check fuses etc otherwise it then may be a case of a new or replacement motor or complete unit. If it is working, then ide follow the pipes incase one has split, again it's a case for listening for air leaks or use a high soapy solution and mist it over the pipes, any leaks will cause bubbles.
May be easier to remove the cover of the air compressor to see and be able to hear better.
Post #511516 Sun Dec 04 2016 2:02pm
