![]() | Home > General > Hi all. Newbie needing advice please |
Satnav - not sure if this is the right procedure but key in a route and then you have to turn up the radio volume when there is a command given (there is also a function to repeat the command too IIRC), the same procedure is used to adjust the volume of the PDC sounds too.
radders1 Member Since: 22 Nov 2016 Location: Preston Posts: 12 ![]() ![]() ![]() |
Thanks for the reply. I'm sure I've tried the volume knob but its difficult to know exactly when a command is being given. I will try that again tomorrow. I can't hear anything other than the bleeping in the car when the sensors are active. |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Hi radders
Thanks Devon. I will try it now |
Sorted Devon thanks very much ![]() ![]() |
glad your sorted |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
The bleeping is going to be a faulty sensor or loom. Bloody annoying, I just disabled mine by taking the fuse out. |
or the P button on the dash will stop the beeping. (until you restart the car) |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I've been pressing the button on the dash for a couple of years. They work in dry weather. |
That'll be a damaged wire. The wires run behind the bumper shroud and can get pinched during a parking bump. Any damage to the insulation lets water in and they go wrong. It's easy to do a temporary repair (my temporary repair is a year old now and going strong so far) but a new loom is cheap too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
