Home > General > Hi all. Newbie needing advice please |
Satnav - not sure if this is the right procedure but key in a route and then you have to turn up the radio volume when there is a command given (there is also a function to repeat the command too IIRC), the same procedure is used to adjust the volume of the PDC sounds too.
Tue Nov 22 2016 8:48pm |
radders1 Member Since: 22 Nov 2016 Location: Preston Posts: 12 |
Thanks for the reply. I'm sure I've tried the volume knob but its difficult to know exactly when a command is being given. I will try that again tomorrow. I can't hear anything other than the bleeping in the car when the sensors are active. |
Tue Nov 22 2016 9:03pm |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
Hi radders
Tue Nov 22 2016 9:28pm |
Thanks Devon. I will try it now |
Tue Nov 22 2016 9:31pm |
Sorted Devon thanks very much That's one down |
Tue Nov 22 2016 9:38pm |
glad your sorted |
Tue Nov 22 2016 9:44pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
The bleeping is going to be a faulty sensor or loom. Bloody annoying, I just disabled mine by taking the fuse out. |
Wed Nov 23 2016 10:25am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
or the P button on the dash will stop the beeping. (until you restart the car) |
Wed Nov 23 2016 12:02pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
I've been pressing the button on the dash for a couple of years. They work in dry weather. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Wed Nov 23 2016 8:37pm |
sounds like I just need to take the fuse out and forget the bloody things |
Fri Nov 25 2016 8:47pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
That'll be a damaged wire. The wires run behind the bumper shroud and can get pinched during a parking bump. Any damage to the insulation lets water in and they go wrong. It's easy to do a temporary repair (my temporary repair is a year old now and going strong so far) but a new loom is cheap too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Nov 25 2016 8:51pm |
