Home > General > wading :) |
david555 Member Since: 08 Nov 2016 Location: east Yorkshire Posts: 28 |
Wed Nov 23 2016 6:53pm |
That poster is a little bit out of date as wading depends which MY of RRS and FFRR. I have a 1996 TDi 300 Defender and an L494 RRS2 and the RRS2's intakes are on the wing top just under the clamshell of the bonnet so with off-road height selected I have 1m wading whereas my 1996 Def has a lot more with extended axle breather, bell housing plugs in and it's Snorkel (it isn't the LR Raised intake which isn't water tight!) BUT normally I wouldn't take the 90 deeper than intake depth which for my 90 is 50cm. L320 RRS (I've have also had 2 of them and offloaded both quite heavily) has the same 50cm as my Defender as the intake is on the wing side - also the RRS OEM Raised intake cannot be used for deep wading as it also is not watertight out of the box, you have to put your own seals into it (and hope they are watertight!). The other problem with pre Puma Defenders is the under windscreen vent system and the ventilation holes around the battery box under the front passenger seat which all let in loads of water......... BTW both my Evoques also had as much wading depth as my 90. The 2 x FFRR's I had both had 50cm wading but L405 has 1.0m like RRS. I believe DiscoSport has 75cm but need to check that. Disco5 has 1m as well.
Wed Nov 23 2016 7:36pm |
I'm getting a 2012 sdv6. Old shape but face lifted I believe.
Wed Nov 23 2016 8:54pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Rule of thumb = wheel centre max
Wed Nov 23 2016 9:01pm |
so when it comes over the bonnet momentarily I should worry Rob 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Wed Nov 23 2016 9:16pm |
Nah...you have a snorkel Visitor from fullfatrr.com
Wed Nov 23 2016 9:31pm |
Wed Nov 23 2016 9:40pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Whilst I had no prior plans to leave my wife I am now seriously considering eloping with your Defender.
600 mm standard height, 700 mm off road height. I don't think you get wet feet if the door seals are good and in any case you'd have a bow wave that would reduce water around the doors, I think. (Not waded more than 100 mm myself!) L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone! |
Thu Nov 24 2016 9:09am |
So what are peoples recommended things to do and protect so I can go full wheel deep, without having any major issues apart from drying out my feet. |
IIRC LR have moved things on a bit since they designed the Defender watertightness which hasn't changed much since 1948! I have not had any issues with deeper wading in either of my L320 RRS's or the L494 I run at the moment BUT I certainly wouldn't take them to full wheel height depths of water unless it was an emergency. Is it your intent to run the car as a purely off-road toy with no normal use, as you may well be the first owner here to have an RRS for wrecking during off-road play? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Nov 24 2016 9:17am |
Depends how far you want to go with it! You can fully seal raised air intake, enclose the ECU behind the battery in a water tight container. But ultimately if your in that deep you will go into super extended height on the suspension and probably be floating by that point!! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Thu Nov 24 2016 9:38am |
If it was a pure off road toy id buy a defender to be honest!
Thu Nov 24 2016 9:47am |
Judging by the photo I posted at the top, which is meant to be for standard vehicles. The range rover has the wheels covered? |
Thu Nov 24 2016 10:08am |
Thu Nov 24 2016 10:51am |
