Home > Maintenance & Modifications > Advice Fitting DRL's To Autobiography Bumper
B9BS X
Hi guys
Ive bought a set of DRL lights off ebay to fit to my AB bumper and just wanted some advise on what the best way to have them wired.
I would like them to come on with ignition, any advice will be much appreciated Thumbs Up
Link for the DRL's - http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
 RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #506505 Tue Sep 27 2016 12:06pm
Sim
United Kingdom 2006 Range Rover Sport TDV6 Autobiography Santorini Black
Let me know how and when you do this, I want to do it too!
Post #507139 Wed Oct 05 2016 10:51pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
They are the ones i fitted in mine, rather bright to match my side lights.
[URL=]
[/URL]
I wired them using a relay from an ignition live off the fuse box, cant remember which one, basically wired the ignition live to the relay, then (used to have) the live from the side lights wired to the relay, so that soon as you turned the sidelights on it pulled the switch inside the relay which then turned off the drls. But then i decided i wanted them on together so i just disconnected that side light live from the relay. So now the drls are operating 100% of the time soon as the ignition is on. They were fitted in January this year and still working perfectly
Post #507162 Thu Oct 06 2016 8:26am
Johnski
If you have access to a Gap Diagnostic IID BT tool, you can set DRL option on, and wire them into sidelights wiring, choose whether to wire with or without having them on, I prefer them on, choice of countries to pick from, as not compulsory in U.K. Use Scandinavia or similar. John
Post #507164 Thu Oct 06 2016 8:35am
B9BS X
Johnski just to confirm if I wire them to the side lights and with the aid of an IID tool I can have the side lights and drl's permanently switched on with ignition by changing the lights settings to Scandinavian? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #507231 Thu Oct 06 2016 10:20pm
If you activate any of the DRL options in the CCF files it will also switch on Dipped Headlights and Tailights, there is no facility to just switch on Sidelights when just Ignition Switched on.
I have gone into the CCF files previously and there are three options listed.
1. DRL Standard
2. Scandinavian
3. Canadian
I activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess.
De-activated that and then activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights.
Post #507239 Fri Oct 07 2016 8:06am
B9BS X
Wired and Fitted Thumbs Up
Post #507764 Thu Oct 13 2016 8:34pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I've been a bit unsure of fitting DRL's myself since finding out the bumper needs cut, but your pics look great so I think I will do it.
Do you have any pics of the hole after it was cut, and any closer pics of it finished? Any tips/advice for doing it, or is it just a case of getting a hacksaw out and cutting?
Thanks
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #508961 Sun Oct 30 2016 8:00pm
B9BS X
Hi insiorc
The fitting was quite straight forward, I marked out were I wanted the DRL's to sit them then drilled 4 small holes in each corner and then used a hacksaw to cut out the hole.
Sorry I never took any pics. When cutting the hole make sure to cut it a few mm smaller to get a tight fit. I couldnt use the bracket/holder that came with the kit as there was no were to screw bracket onto so just made the hole a couple of mm smaller for a tight fit and then bonded the DRL's from behind so there not going to fall out.
Post #508981 Sun Oct 30 2016 10:15pm
insiorc
Thanks B9BS X
I'll just need to be brave then...
Post #508985 Sun Oct 30 2016 10:22pm
B9BS X
Piece of cake Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #508986 Sun Oct 30 2016 10:28pm
Bill Portland
B9BS X
Where did you end up wiring them too? Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #549353 Wed Feb 21 2018 11:56am
B9BS X
Wired them upto ignition live so came on automatically on key Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #549516 Fri Feb 23 2018 2:32pm
gvw
These look really good - could you please post some close up photos of the lights in situ
Thanks Thumbs Up
Post #549604 Sat Feb 24 2018 7:52pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Just found this thread which is exactly what i want to do with mine, did any of you have to take the bumper off to cut the hole and bond them in? I think tiger seal will do with it been black. Do they stay on at night or have you dimmed them some how?
Post #610912 Tue Mar 02 2021 9:23pm
