![]() | Home > Maintenance & Modifications > Advice Fitting DRL's To Autobiography Bumper |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Hi guys
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Sim Member Since: 02 Oct 2016 Location: London Posts: 13 ![]() ![]() ![]() |
Let me know how and when you do this, I want to do it too! |
If you have access to a Gap Diagnostic IID BT tool, you can set DRL option on, and wire them into sidelights wiring, choose whether to wire with or without having them on, I prefer them on, choice of countries to pick from, as not compulsory in U.K. Use Scandinavia or similar. John
Johnski just to confirm if I wire them to the side lights and with the aid of an IID tool I can have the side lights and drl's permanently switched on with ignition by changing the lights settings to Scandinavian? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
If you activate any of the DRL options in the CCF files it will also switch on Dipped Headlights and Tailights, there is no facility to just switch on Sidelights when just Ignition Switched on.
Wired and Fitted |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I've been a bit unsure of fitting DRL's myself since finding out the bumper needs cut, but your pics look great so I think I will do it.
Hi insiorc
![]() EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Thanks B9BS X
Piece of cake |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 393 ![]() ![]() ![]() |
B9BS X
Wired them upto ignition live so came on automatically on key |
gvw Member Since: 18 Nov 2015 Location: South Yorkshire Posts: 5 ![]() |
These look really good - could you please post some close up photos of the lights in situ
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 247 ![]() ![]() ![]() |
Just found this thread which is exactly what i want to do with mine, did any of you have to take the bumper off to cut the hole and bond them in? I think tiger seal will do with it been black. Do they stay on at night or have you dimmed them some how? |
