Home > Maintenance & Modifications > Size of the oil sump plug and turbo sump plug?
eyespider
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Java Black
Hi all
I've had dimple magnetic sump plugs fitted to my cars in the past I would like to get two to put on my new RRS TDv8 engine.
Does anyone know what size so I can make an order?
regards
Post #507486 Mon Oct 10 2016 10:18am
I think you only need 1.
THese sump plugs have a rubber seal in them.
Post #507495 Mon Oct 10 2016 11:15am
Camelrock
On the TDV8 you need 2 both the same part no. It's the same plug on the v6 engines, easiest way to get correct thread etc would be to get one there about £2.50 each from dealer 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #507498 Mon Oct 10 2016 12:08pm
eyespider
Hi is the part number 1013938?
I think I will stick to the origional plugs due to the rubber washer not being present on the dimple.
Post #507757 Thu Oct 13 2016 6:14pm
Camelrock
Sorry don't know the part no. Best thing for these engines is regular oil and filter changes. Do mine every 5k and always drain both bungs. The other thing is always let the engine tick over for a minute or so after every journey to let the turbos cool down, drives the Mrs mad.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #507779 Thu Oct 13 2016 9:21pm
