![]() | Home > Maintenance & Modifications > Size of the oil sump plug and turbo sump plug? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I think you only need 1.
On the TDV8 you need 2 both the same part no. It's the same plug on the v6 engines, easiest way to get correct thread etc would be to get one there about £2.50 each from dealer 2008 G4 RRSport TDV8 current
eyespider Member Since: 09 Oct 2016 Location: Oxford Posts: 15 ![]() ![]() ![]() |
Hi is the part number 1013938?
Sorry don't know the part no. Best thing for these engines is regular oil and filter changes. Do mine every 5k and always drain both bungs. The other thing is always let the engine tick over for a minute or so after every journey to let the turbos cool down, drives the Mrs mad.. 2008 G4 RRSport TDV8 current
