Home > Faults & Fixes > Front anti roll bar bushes
Gilly1
hi, I had a try at front ARB rubbers today, I thought it would be remove replace bish/bash/bosh/ & job done, (NO CHANCE)
I bought replacements in picture 2 but I have the brackets in picture 1, are the ones in pic 2 replacements for swan neck brackets in pic 1, also after taking under tray of I could get to all 3 bolts on drivers side but looking at passengers side there looks so little space between top bolt and shaft direct above. I found the how two (disco forum) but they are removing ones from picture 2 and looks different roll bar to mine. I've got same setup as picture 1.
Post #506910 Sun Oct 02 2016 5:20pm
Disco_Mikey
Picture 1 is the DR/ARC ARB's
Picture 2 is the standard ARB setup to early + low spec RRS, and all D3/4 Thumbs Up
Post #506919 Sun Oct 02 2016 7:14pm
1 is dynamic anti roll bar. 2 is the passive bar as fitted to Disco 3. Disco instructions won't help really. I think the front dynamic bar needs the body lifting a touch or something else removing first.
DM beat me to it! 2012 SDV6 - it's missing a couple of cylinders
Post #506920 Sun Oct 02 2016 7:21pm
Gilly1
Ahh that will explain why there different then lol, holly c**p part body lift just to fit ARB rubbers, LR really don't like making it easy for the home DIY"er..
Post #506921 Sun Oct 02 2016 7:27pm
DrRob
T and S Norman might be able to help....? Visitor from fullfatrr.com
Post #506924 Sun Oct 02 2016 7:31pm
Gilly1
Thanks dr rob, will contact them if can't get round lifting front, has anyone managed to fit front ARB rubbers without lifting body up, I don't mind purchasing a (special spanner) if needed, I'm not even 100% sure that is the low speed rough road tapping/rattling I can hear, I get a bit of movement with pry bar, pretty sure it's not control/wishbone arms because my last sport had Definitive clunk when applied brakes at low speed and dealer had them changed before I completed sale.
Post #506963 Mon Oct 03 2016 5:06pm
Paddi
Hi Gilly,
As I understand it there is no need to lift the body to do the front ARB bushes but it is necessary for the rears although not a complete body off - just a slight lift.
Have you seen this thread?: http://www.rrsport.co.uk/forum/topic44478....cial+tools
Might be useful. Good luck!
I'm contemplating the same job. 2008 MY Java Black TDV8 HSE
Post #506967 Mon Oct 03 2016 7:10pm
Gilly1
Thanks paddi that's great help, Thumbs Up will give it another go week end. Very Happy
Post #506975 Mon Oct 03 2016 8:42pm
trennaa
Australia
Gilly I did mine last weekend and it's possible without the special tools but not the most enjoyable job I have done, a Flexi head ratchet spanner helps for sure but they are so tight so to get them started or nipped up tight I bent a ring spanner to get it up and over, I found the Flexi head ratchet spanner had a fair bit of play in the pivot when you put heaps of pressure on it and as it is so tight in there I found it easy to bend a spanner and leaver of the chassi etc. with a screwdriver handle and when there was nothing to lever off I put a chain on the ring spanner and had another person pulling the chain through the wheel arch with a screwdriver through the chain and levering off the chassi. I know it is not the most conventional way but it worked really well.
Post #507256 Fri Oct 07 2016 12:09pm
Socast
There's no need to lift the body when replacing either set of bushes. Front require that the drive shaft be unbolted and lifted up, rear take 15 mins a side to do, it takes longer to jack up the car and remove the wheel than it does to change each bush.
Post #507263 Fri Oct 07 2016 2:26pm
Gilly1
Thanks all for reply,s, I'm going into battle today & hopefully I come out victorious, 🙏
Post #507385 Sun Oct 09 2016 8:54am
