Home > Faults & Fixes > Front anti roll bar bushes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Picture 1 is the DR/ARC ARB's
Sun Oct 02 2016 6:14pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9011 |
1 is dynamic anti roll bar. 2 is the passive bar as fitted to Disco 3. Disco instructions won't help really. I think the front dynamic bar needs the body lifting a touch or something else removing first.
Sun Oct 02 2016 6:21pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Ahh that will explain why there different then lol, holly c**p part body lift just to fit ARB rubbers, LR really don't like making it easy for the home DIY"er.. |
Sun Oct 02 2016 6:27pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
T and S Norman might be able to help....? Visitor from fullfatrr.com
Sun Oct 02 2016 6:31pm |
Thanks dr rob, will contact them if can't get round lifting front, has anyone managed to fit front ARB rubbers without lifting body up, I don't mind purchasing a (special spanner) if needed, I'm not even 100% sure that is the low speed rough road tapping/rattling I can hear, I get a bit of movement with pry bar, pretty sure it's not control/wishbone arms because my last sport had Definitive clunk when applied brakes at low speed and dealer had them changed before I completed sale. |
Mon Oct 03 2016 4:06pm |
Hi Gilly,
Mon Oct 03 2016 6:10pm |
Thanks paddi that's great help, will give it another go week end. |
Mon Oct 03 2016 7:42pm |
trennaa Member Since: 01 Aug 2014 Location: Tasmania Posts: 4 |
Gilly I did mine last weekend and it's possible without the special tools but not the most enjoyable job I have done, a Flexi head ratchet spanner helps for sure but they are so tight so to get them started or nipped up tight I bent a ring spanner to get it up and over, I found the Flexi head ratchet spanner had a fair bit of play in the pivot when you put heaps of pressure on it and as it is so tight in there I found it easy to bend a spanner and leaver of the chassi etc. with a screwdriver handle and when there was nothing to lever off I put a chain on the ring spanner and had another person pulling the chain through the wheel arch with a screwdriver through the chain and levering off the chassi. I know it is not the most conventional way but it worked really well. |
Fri Oct 07 2016 11:09am |
There's no need to lift the body when replacing either set of bushes. Front require that the drive shaft be unbolted and lifted up, rear take 15 mins a side to do, it takes longer to jack up the car and remove the wheel than it does to change each bush. |
Fri Oct 07 2016 1:26pm |
Thanks all for reply,s, I'm going into battle today & hopefully I come out victorious, 🙏 |
Sun Oct 09 2016 7:54am |
