Home > Maintenance & Modifications > 4.2 Supercharged Exhaust Question |
Spanner Member Since: 22 Aug 2016 Location: Staffordshire Posts: 35 |
I've got the Magnaflow fitted to mine and it sounds glorious, not boy racery at all. Fairly quiet at tickover but lets you hear the engine when you hoof it a bit |
Mon Sep 26 2016 5:47am |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
Is it a cat back system with a x pipe and one centre box the same setup as the pic above?
Tue Sep 27 2016 12:32am |
It's a single box as in the pic but can't remember if there's an x pipe, pretty sure there isnt and it's two separate pipes running into the box.
Tue Sep 27 2016 5:41am |
Paul_selby Member Since: 05 Sep 2016 Location: North Yorkshire Posts: 35 |
May help anyone who hasn't seen what they're exhaust looks like off ! Removed it to replace rear brake pipes. Shows the 2 bolt flange and slip on pipes onto front section.
Tue Sep 27 2016 9:44am |
So its a single box in the middle and 2 straight pipes all the way to the tips? Must sound awesome Any chance of a little video clip to hear the sound of your beast? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Tue Sep 27 2016 10:43am |
Are both boxes in the middle necessary or is the oval pear funny shaped one after the centre box just to quieten the sweet sounds of the V8
Tue Sep 27 2016 10:52am |
The first box is the swirl chamber where the gasses are balanced. The 'snail shell' is the resonator that eliminates most of the bass from the exhaust note. The rear cans control the volume.
Tue Sep 27 2016 11:08am |
I'll see what I can do later when I get home. I think it sounds glorious |
Tue Sep 27 2016 11:10am |
So while im at the exhaust centre and to get a nice growl from my supercharged V8 would you say get rid of the snail shell resonator (the odd looking box) and both back boxes, so straight through pipe from centre box to both tips? Wow that V8 would definitely start to growl Id love the growl on low speeds but do you think it might be too loud on motorway/high speed? And im guessing it may improve a little power? or am I wrong to assume and will lose power? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Tue Sep 27 2016 11:32am |
Nice one spanner that would be great Is your RRS also have a Supercharged V8 4.2/5.0? Hows the sound of your car now on motorway speeds? And did u experience any improvement on power after fitting your exhaust? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Tue Sep 27 2016 11:35am |
Yes, mines a 4.2 S/C. To me it's fine at motorway speeds, not intrusive at all when you're cruising, just barks a bit when you put your foot down. I felt that there was a slight increase in power but that may be due to me driving it harder because I love the exhaust note |
Tue Sep 27 2016 11:51am |
Here's a link to the same exhaust on YouTube. I don't think it quite does it justice but it gives you the idea. Not sure if it'll work as first time posting a link! If not just search range rover sport Magnaflow
Tue Sep 27 2016 11:58am |
Great stuff
Tue Sep 27 2016 12:01pm |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 |
How did you get on? I've just had the resonator and the back boxes removed. Sounds absolutely glorious, but silent when keeping a steady speed. My favourite noise is when in sport mode, if you're slowing down, and the gear drops, there's a lovely V8 crackling noise.
Wed Oct 12 2016 9:13am |
