![]() | Home > Technical > Replacing sun roof drainage tube in engine compartment |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, have you put a bead of silicone around each clip when replacing down the A pillar ???? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Hi again, have you removed the foam block ??? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Hi.
Hi, i read on here somewhere that it was important to put silicone around the clips on the A pillar or it wasn't worth doing. Also was it a slot that you covered over and what did you cover it with.... i used duct tape because other tapes will come off. Hope this helps , it done it for me |
Hi, the patch with the plugs was used to cover the enlongated hole.
After weeks of dry weather we had torrential downpour for 2 days and my passenger footwell is lined up as the next venue for Olympic diving.
Charliecloud Member Since: 21 Oct 2016 Location: Tonbridge Posts: 23 ![]() ![]() |
If you want to get rid of every last drop of water,buy a cheap dehumidifier off of ebay or other discount websites that runs off of the mains and put it in the car overnight, after you have fixed the leak . |
Absolutely. need it dry and no possibilities of mould and smelly fabric.
So, 2 weeks after having the (what would be your ) drivers side sun roof drainage tube replaced, all seems to be 'dry'.
what |
not quite following you?
Hi, could be my friend, but hope its not |
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 48 ![]() ![]() |
Hello. I have a RRS S/C 2005. LHD. My left/drivers window stoped working. I have found out that it can be
Now to fix the window problem |
