Home > Technical > Replacing sun roof drainage tube in engine compartment |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, have you put a bead of silicone around each clip when replacing down the A pillar ???? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Sep 05 2016 8:01pm |
Hi again, have you removed the foam block ??? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Sep 05 2016 8:02pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Hi.
Tue Sep 06 2016 4:22am |
Hi, i read on here somewhere that it was important to put silicone around the clips on the A pillar or it wasn't worth doing. Also was it a slot that you covered over and what did you cover it with.... i used duct tape because other tapes will come off. Hope this helps , it done it for me 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Tue Sep 06 2016 7:41am |
Hi, the patch with the plugs was used to cover the enlongated hole.
Tue Sep 06 2016 8:02am |
After weeks of dry weather we had torrential downpour for 2 days and my passenger footwell is lined up as the next venue for Olympic diving.
Wed Nov 02 2016 10:12am |
Charliecloud Member Since: 21 Oct 2016 Location: Tonbridge Posts: 23 |
If you want to get rid of every last drop of water,buy a cheap dehumidifier off of ebay or other discount websites that runs off of the mains and put it in the car overnight, after you have fixed the leak . |
Wed Nov 02 2016 10:19am |
Absolutely. need it dry and no possibilities of mould and smelly fabric.
Wed Nov 02 2016 2:01pm |
So, 2 weeks after having the (what would be your ) drivers side sun roof drainage tube replaced, all seems to be 'dry'.
Mon Nov 28 2016 8:40pm |
what . you don't think that water has got in there by any chance do you ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Nov 28 2016 10:56pm |
not quite following you?
Tue Nov 29 2016 7:16am |
Hi, could be my friend, but hope its not seem a strange one but i hope you have stopped the leak. 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Tue Nov 29 2016 8:53am |
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 48 |
Hello. I have a RRS S/C 2005. LHD. My left/drivers window stoped working. I have found out that it can be
Thu Dec 01 2022 12:35am |
Now to fix the window problem |
Thu Dec 01 2022 12:36am |
