![]() | Home > Maintenance & Modifications > Alarm keeps going off saying Bonnet Open on Dash |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
Alarm keeps going off, saying on dash Bonnet Open, even though it appears to be closed!
This has happened to me, after topping up fluids, if I close the bonnet gently then use hands to lock it.(pushing down on bonnet using hands) On locking car it bleeps and it's always the bonnet, so I drop it closed from mid height and all is ok. Why it does this I don't know, it always looks fully down and held on car he's, but will look into it when I have more time. Try it and see if it clears your fault. Otherwise may just require adjustment, or replacement. |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Crook bonnet switch right hand side under the right hand bonnet catch. (From drivers seat view)
Thanks Guys I shall look into this
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
If you unplug the sensor you can bridge the connection with a paperclip or similar. Stop alarm going off in the mean time, then yoe might as well just replace as theyre only cheap.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Hi Guys thanks for your input, today I got an original latch from Lookers Park Royal, and hey presto problem solved. Total cost £23.00.
