Home > Maintenance & Modifications > Brake problem
Black Bess
Sorry I did not reply sooner. I have been on holiday!
My car goes into the dealer tomorrow, so I will be able to report more when it has been there.
What happens is that the brakes are fine until you hold the brake on for a longer period, such as a long deceleration or manoeuvring on a slope. In that situation the brake servo seems to run out of vacuum. The brakes are still there, but you have to press very hard when there is no servo assistance. After a few moments of releasing the brake, servo assistance is restored. I think the vacuum pump has lost efficiency.
Post #502378 Mon Aug 08 2016 8:56am
Black Bess
Well Black Bess has been into the local dealer for the recall. They fitted a new brake servo (they call it a booster) and some new pipework between servo and vacuum pump which incorporates a filter and return pipe to stop the engine oil coming through.
The brake problem seems to be cured, all for free and they even washed the car!
The first time she has been back to the dealer since they supplied her in 2008.
Post #502666 Fri Aug 12 2016 12:23pm
kozzone
Finland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Thanks for the info Black Bess! I've ordered all the new parts now. Does anyone know if there are some sort of instruction how to remove the servo and does this job require a lot of disassembling to be done? Im most likely giving this job to a indie but I want to provide them all the help I can to speed up the job.
Too bad this recall was already done to my car so I'm paying all of this Sad so I'm guessing this problem will appear in the future once again. Or at least I'm not aware that these new part would be any different than those that were installed in the recall procedure. Correct me if I'm wrong Smile
-Toni
Post #502716 Sat Aug 13 2016 10:07am
Bodsy
Site Sponsor
Even for cars it's already been done on, if it hasn't fixed the problem, then in almost all cases, LR will carry it out free of charge.
But for changing the brake booster, it's pretty straight forward. Only tricky bit is getting the clip off the pin attached to the brake peddle. The rest of it is straight forward. I've got loads of photos to do a how to from when I did mine, just need time to do it! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #502717 Sat Aug 13 2016 10:20am
Bodsy
Site Sponsor
This gives you the pin and Spring clip, so you can see how you need to lever it to get it off.
 Bodsys Brake Bible
See it HERE
Post #502718 Sat Aug 13 2016 10:23am
kozzone
A little update. So I received the parts for the job and reserved a time from LR service. But unfortunately I received RHD versions of the parts and my RRS is LHD.
So my question is can I use the vacuum line (LR018673) for LHD car and the master cylinder (LR014527). Are there physical differences? The parts I actually need would be LR018674 and LR014528 The brake booster seems to fit to both so thats ok.
Br.
Toni
Post #504442 Sat Sep 03 2016 10:44am
Black Bess
Oh that is frustrating.
As you say, the booster is universal. I believe the master cylinder is handed, because when I bought my replacement, there was a LHD option available.
The pipes from the vacuum pump, I think, will also be handed because they are preformed 'hard plastic' so I do not think the RHD will fit on a LHD. I think you will need the correct version.
Adam..
Post #504530 Mon Sep 05 2016 8:32am
kozzone
A small update for this case.
Just got the job done yesterday at LR dealer. The difference in the braking power is so huge it feels like I've never even had a booster lol. It feels so good now.
The total cost for the labor was 264€ or £228. Parts for the job were £345.
And yes the booster was universal. It fits for LHD and RHD. The master cylinder was different and the vacuum pipe were totally different in LHD. Half longer in measure and so on...
They also changed all of the brake fluid but that was cheap.
Br.
Toni
Post #506260 Sat Sep 24 2016 2:14pm
Black Bess
Good to hear that you have got it all sorted out now.
Adam..
Post #506419 Mon Sep 26 2016 8:00am
