![]() | Home > Maintenance & Modifications > Brake problem |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Well Black Bess has been into the local dealer for the recall. They fitted a new brake servo (they call it a booster) and some new pipework between servo and vacuum pump which incorporates a filter and return pipe to stop the engine oil coming through.
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 ![]() ![]() ![]() |
Thanks for the info Black Bess! I've ordered all the new parts now. Does anyone know if there are some sort of instruction how to remove the servo and does this job require a lot of disassembling to be done? Im most likely giving this job to a indie but I want to provide them all the help I can to speed up the job.
Even for cars it's already been done on, if it hasn't fixed the problem, then in almost all cases, LR will carry it out free of charge.
This gives you the pin and Spring clip, so you can see how you need to lever it to get it off.
A little update. So I received the parts for the job and reserved a time from LR service. But unfortunately I received RHD versions of the parts and my RRS is LHD.
Oh that is frustrating.
A small update for this case.
Good to hear that you have got it all sorted out now.
