![]() | Home > General > HID Bulb replacement, different setup to the usual |
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 ![]() ![]() ![]() |
Ok after a bit more research it turns out the new headlight uses D1S bulbs instead of D2S |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Yes, I went through the same learning experience.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
The bulb type is actually moulded in to the top of the clear headlight cover along with a load of other info. You can see it when you open the bonnet. 2012 SDV6 - it's missing a couple of cylinders
