Home > General > HID Bulb replacement, different setup to the usual |
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 |
Ok after a bit more research it turns out the new headlight uses D1S bulbs instead of D2S |
Sat Aug 06 2016 5:41pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Yes, I went through the same learning experience.
Sat Aug 06 2016 5:56pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
The bulb type is actually moulded in to the top of the clear headlight cover along with a load of other info. You can see it when you open the bonnet. 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 07 2016 7:36am |
