![]() | Home > Technical > towbar help please |
you can get the green handle lock mechanism off ebay |
banditpirate Member Since: 07 Apr 2016 Location: london Posts: 5 ![]() ![]() |
I can get the actual lock its the other internal bits I need I can seem to find then anywhere |
Sounds like it's goosed if there is no securing bolt |
Hmmmm, never seen one like that. Best bet would be to give Dan at Duckworths a call and see if he can get you the blueprint or the bits required. ON THE WAY: BMW F21 M140i
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
hi did you have any joy getting the bits you need I am in the same boat |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Mine is close to that I need the red ring that sits on the tow bar under the lock and a new lock 61 AB 5.0 supercharged rocket
hi
