Home > Technical > towbar help please |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
you can get the green handle lock mechanism off ebay |
Mon Jul 25 2016 10:13am |
banditpirate Member Since: 07 Apr 2016 Location: london Posts: 5 |
I can get the actual lock its the other internal bits I need I can seem to find then anywhere |
Mon Jul 25 2016 11:12am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Sounds like it's goosed if there is no securing bolt , do you have a picture of what you're faced with?
Mon Jul 25 2016 11:17am |
Mon Jul 25 2016 11:28am |
Hmmmm, never seen one like that. Best bet would be to give Dan at Duckworths a call and see if he can get you the blueprint or the bits required. ON THE WAY: BMW F21 M140i
Mon Jul 25 2016 11:44am |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 |
hi did you have any joy getting the bits you need I am in the same boat |
Fri Aug 05 2016 3:33pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Mine is close to that I need the red ring that sits on the tow bar under the lock and a new lock 61 AB 5.0 supercharged rocket
Fri Aug 05 2016 6:07pm |
hi
Fri Aug 05 2016 10:29pm |
