Home > Maintenance & Modifications > Brake problem |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
There is a known issue with oil getting in to the brake servo. Should have been done as a recall so might be worth talking to LR about it. 2012 SDV6 - it's missing a couple of cylinders
Mon Jun 27 2016 9:05am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Ah yes, I wondered about that. I will investigate the servo and see what is going on, I think. It does feel as though vacuum is being lost after a long brake application. On the next application, it has come right back again.
Tue Jun 28 2016 8:13am |
This is def brake booster problem.
Tue Jun 28 2016 8:17am |
Thank you Bodsy, just the advice I was looking for.
Tue Jun 28 2016 8:20am |
Ebay is ere I sourced mine from. One came from a main LR dealer and the other from a LR parts supplier. All genuine. Haven't really looked for aftermarket ones as at those prices, it was a bargain. Main dealer normal prices are significantly higher! Bodsys Brake Bible
Tue Jun 28 2016 8:25am |
SJJ500080 for the S/C booster
Tue Jun 28 2016 8:31am |
Brilliant, Thank you.
Thu Jun 30 2016 3:29pm |
I removed the master cylinder last night to investigate this problem. The servo was half full of engine oil!!
Wed Jul 27 2016 8:27am |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
May be of help
Wed Jul 27 2016 8:53am |
Thank you. Actually mine pre-dates that recall, being registered in September 2005, but I think I will speak to the dealer about it and see what they say. |
Wed Jul 27 2016 10:17am |
Given JLR's generally er..... 'relaxed' attitude to things like record keeping, quality control and documentation accuracy I'd say there is a good chance that your vehicle should have had the recall rectification work.
Wed Jul 27 2016 1:23pm |
Well I contacted my local dealer and it appears that a recall does affect my vehicle, so I have booked it in and will see what they make of it. The recall is on loss of vacuum assistance and relates to the vacuum pump. So I will be highly delighted if they change it for me for nothing.
Thu Jul 28 2016 8:04am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4983 |
As you too have found out; I found another TSB, which adjusts the date to the start of production of the RRS |
Thu Jul 28 2016 11:51am |
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 |
Have you got any update on this? Im having the same exact symptoms on my 07'. I contacted a LR dealer and they told me this recall has already been done to my car years ago. So could you advice me what parts should I get to fix this problem Or what did they change on your car. -Toni EDIT: Sorry I misread when you posted. So I'll be waiting silently here in the corner for your update EDIT2: Also you can hear weird noise when I press brake pedal for a while even when stationary. And this all happens when I press brake for a longer time. Not when its applied for a short period of time. |
Fri Jul 29 2016 11:41am |
