Home > Technical > replacing arb bushes front (rrs with ace)
Iceman08
Thanks again Rob Thumbs Up
Does the prop need to be removed to remove the one bolt below it?
Post #500391 Fri Jul 08 2016 7:18pm
RobP
Dont need to remove completely but will need the prop undoing from front diff and moving out the way although it wont move much just lift up slightly towards the underside of floor and secure with a tie wrap
Be careful....
The end of the prop has a plastic shield that covers the flange so good idea is to pop a tie wrap through the bolt hole on plastic shield and through flange to prevent you spending ages afterwards trying to get the paper gasket that is sandwiched between the shield and flange lined up to put the Censored bolts back into prop. You can guess how I know this Big Cry TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #500401 Fri Jul 08 2016 9:28pm
Iceman08
Top tip about the flange Rob........I feel your pain Shocked
When I removed my prop on my D3 I found I hand to move the vehicle slightly forward to turn the prop so I could get to all the bolts........is that the case in this instance too?
Bow down
Post #500420 Sat Jul 09 2016 8:52am
RobP
No need to move vehicle but you will need to out gearbox in neutral and have a helper press brake to hold still while you undo Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #500422 Sat Jul 09 2016 10:19am
Iceman08
I presume you had all 4 wheels off the ground to do it that way?
As we only have 2 axle stands I guess we need to undo half the bolts then move the vehicle to get access to the others?!
Post #500430 Sat Jul 09 2016 11:34am
RobP
No just front two wheels on axle stands. With the gearbox in neutral you should be able to spin the prop all the way round TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #500440 Sat Jul 09 2016 12:57pm
Iceman08
Week late reply........but........we did it Thumbs Up
I was getting myself in a muddle thinking the prop wouldn't spin but as you pointed out it will with the wheels raised! Embarassed
Thanks for your advice Rob, it was greatly appreciated
Bow down Bow down
Post #500959 Fri Jul 15 2016 10:33pm
RobP
No problem glad it worked for you Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #500961 Fri Jul 15 2016 10:55pm
jcw
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
For anyone in Oxfordshire area, I had James French in Standlake replace mine (2005 SC) and was charged just an hours labour.
Post #500966 Sat Jul 16 2016 8:43am
kttlaweb
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Anyone had this done in the Derbyshire area, any ideas on cost?
Post #504221 Wed Aug 31 2016 6:10pm
