![]() | Home > Technical > replacing arb bushes front (rrs with ace) |
Iceman08 Member Since: 09 Mar 2016 Location: Hereford Posts: 8 ![]() |
Thanks again Rob |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Dont need to remove completely but will need the prop undoing from front diff and moving out the way although it wont move much just lift up slightly towards the underside of floor and secure with a tie wrap
No need to move vehicle but you will need to out gearbox in neutral and have a helper press brake to hold still while you undo |
I presume you had all 4 wheels off the ground to do it that way?
No just front two wheels on axle stands. With the gearbox in neutral you should be able to spin the prop all the way round TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Week late reply........but........we did it |
No problem glad it worked for you |
jcw Member Since: 04 Jan 2016 Location: Gloucestershire Posts: 8 ![]() ![]() ![]() |
For anyone in Oxfordshire area, I had James French in Standlake replace mine (2005 SC) and was charged just an hours labour. |
kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16 ![]() ![]() ![]() |
Anyone had this done in the Derbyshire area, any ideas on cost? |
