![]() | Home > Technical > replacing arb bushes front (rrs with ace) |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
You don't need anything special other than a garage and patience to replace the front arb bushes. Your local garage should be able to do it without any real issues. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Unless the bolts are seized into the crossmember, which does happen more frequently than I would like, then it needs some (a lot of) heat... |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9023 ![]() ![]() ![]() |
The frequency that my ARB bushes are changed, I'd be amazed if the bolts had time to seize... |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Having just replaced my ARB bushes along with complete new ARB too there is no way I would have attempted it without the two special tools (Thanks Dan @ Duckworths |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
robp
One of this set of Halford pro
Thanks robp |
Iceman08 Member Since: 09 Mar 2016 Location: Hereford Posts: 8 ![]() |
What are the two special tools please?! |
Details of the part numbers and price from Dan at Duckworth in THIS thread
Top man, thanks Rob |
The other thing I've read is there has been an upgrade to the clamps, is it worth changing these as well as the bushes?
Mine was a full anti roll bar replacement so it came with new bushes and clamps but yeah if changing the bushes for first time I would change the clamp too TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
I do have access to a ramp but it's a bit tricky at the moment, so I was wondering if it's possible to change the bushes with it on axle stands?
Yes its possible, If I can change the whole ACE ARB on a pair of axle stands then bushes are definitely doable though it is tight TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
