![]() | Home > Maintenance & Modifications > Auto wiper sensor |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
If you drop the access by 50mm it will also drop Standard and off Road Height as well you cannot drop one on its own it's either all or none. Also if you drop access height to much I think you may find the vehicle will sense itself as grounded and raise itself to possibly off road height. I believe there are some systems you can buy and fit which do allow the height to be changed independently but can't be done with the GAP IID Diag. tool.
Thanks Col, back to the drawing board, this is the only problem with this lovely car, have to see the minimum I can drop it to ease access. Hadn't realised that other heights would alter, and as off road frequently will have to consider that too. |
Forgot to mention you can save three different setting with the Gap tool, but obviously you would have to plug the tool in to select which setting you wanted, which I suppose wouldn't be to much trouble if you wanted to go off roading then re-set using tool for normal road use.
Not a problem setting up and using IID Gap tool, thanks once more. |
