Home > Maintenance & Modifications > Auto wiper sensor |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
The auto lights is just normal for these cars unfortunately.
Wed Jun 29 2016 5:32pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Hi Andy, it's just that I was getting a bit sensitive, I think I was getting auto light envy when driving past merc & BMWs with there's on. But around 7.30pm on a dark and gloomy/rainy evening they finally came on. As for the wiper even when not raining 1 click up (auto) they just work like intermediate approx 2 or 3 sweeps every 30sec or so. |
Thu Jun 30 2016 7:17am |
It is a while since I owned an L320 RRS but on the wiper stalk do you have a second ring that looks like you can vary the interval between sweeps? In "auto" mode this will also vary the "sensitivity" of when the wipers will come too IIRC. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 30 2016 8:26am |
On mine with auto wipers the ring adjusts the REAR wiper delay which is useful.
Thu Jun 30 2016 10:21am |
I just purchased a iiD tool (non Bluetooth) from eBay, I'll have a look and see if that confirms anything, If tried the wiper adjuster but doesn't seem to make no difference |
Thu Jun 30 2016 11:04am |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
The IID tool will have to be matched to your VIN first for it to work properly. Of course you may have done that and still found no alteration? Also ensure you have the latest software by downloading to IID tool via a PC or Mac. John
Thu Jun 30 2016 1:37pm |
Hi johnski, not received iiD tool yet, should arrive sat, I've emailed GAP and they have provided a link for me to do owner & vin transfer, I'm really not the best with computers & software gadgets but hopefully I will get my head round it, with the iiD can I alter the ride height, my car at normal height is 200mil each corner, can I reduce to 170/180, |
Thu Jun 30 2016 4:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
You can change the ride height permanently if you wish but don't forget to get a 4 wheel alignment done at the new height. 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 30 2016 8:47pm |
I have a scanned article from Land Rover Owner magazine about a German aftermarket suspension adjusting system (they take it up above, as well as down, beyond the normal limits) in my galleries here
Fri Jul 01 2016 8:15am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Out of curiosity where are you taking those measurement's from? 200mm is not right, they should be something like 461mm + or - 12mm Front and 465mm + or - 13mm Rear in standard height. Not sure they are the exact figures but not far out. The measurement is taken from the Centre of the Wheel/Cap to lower edge of Wheel Arch if I remember correctly. Cheers Col |
Fri Jul 01 2016 9:05am |
Hi col, I read somewhere to take measurements from top of wheel rim to bottom centre wheel arch. |
Fri Jul 01 2016 9:13am |
Found this.
Fri Jul 01 2016 9:28am |
Ah, I will check it out in bit, thanks. |
Fri Jul 01 2016 11:48am |
Thanks for that, I wouldn't have remembered to have the tracking/alignment checked. I need to drop the access height, if possible, about 50mm+, to give better access for a disabled person that struggles to get in and out at present access height setting, if I forget to lower they have no chance. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Fri Jul 01 2016 9:39pm |
