Home > Maintenance & Modifications > Auto wiper sensor
If you drop the access by 50mm it will also drop Standard and off Road Height as well you cannot drop one on its own it's either all or none. Also if you drop access height to much I think you may find the vehicle will sense itself as grounded and raise itself to possibly off road height. I believe there are some systems you can buy and fit which do allow the height to be changed independently but can't be done with the GAP IID Diag. tool.
Post #500024 Fri Jul 01 2016 9:59pm
Johnski
Thanks Col, back to the drawing board, this is the only problem with this lovely car, have to see the minimum I can drop it to ease access. Hadn't realised that other heights would alter, and as off road frequently will have to consider that too. Thumbs Up John
Post #500025 Fri Jul 01 2016 10:33pm
Forgot to mention you can save three different setting with the Gap tool, but obviously you would have to plug the tool in to select which setting you wanted, which I suppose wouldn't be to much trouble if you wanted to go off roading then re-set using tool for normal road use.
Post #500027 Fri Jul 01 2016 10:50pm
Johnski
Not a problem setting up and using IID Gap tool, thanks once more. Bow down John
Post #500029 Fri Jul 01 2016 11:56pm
Gilly1
Auto wiper fault solved, I removed the plastic housing from behind the rear view mirror and found that the auto wiper/headlight sensor was loose on 1 side, there is a small black clip on the bottom corner off the sensor so I popped it to the open position then pushed the sensor against the screen and punched the clip closed, that hooks into the sensor so how and holds it into place so sensor is properly fitted snug to screen again, refit plastic housing, sprayed some water on window and just like a miracle the auto wipers started working. Thumbs Up Hopefully the lights will not wait so long to come on now as the sensor is in correct position. Very Happy
Post #500035 Sat Jul 02 2016 8:35am
