Home > Maintenance & Modifications > Powerflush
Plazmapete
Powerflush
I'm having problems whilst driving. Car judders but not all the time. Read a couple of posts about powerflushing. Spoken to a couple of local garages who told me the German gearbox manufacturers recommend NOT to have them flushed. Luckily the car is under warranty so should be covered. Had quotes of £1200 for replacement torque converter and £1800+ for new converter and gearbox stripping and rebuild.
Post #498556 Mon Jun 13 2016 12:09pm
Flush at £250 or recon the gearbox at £1800. Hardly surprising which one they'd like you to do. Whistle
There are innumerable members on Disco3 and here that have had the gearbox flushed and had good results - I'm one of them. The key is to have it done early enough to avoid the usual issues starting.
I had my gearbox recon'd at Christmas and will be getting a flush done every two years (which will be c.50,000 miles at current usage). I had the box flushed at about 75,000 miles. Thought I had a torque converter issue but it turned out to be worn splines on the output shaft - hence the recon.
Edit: should clarify that the flush was done at 75k but the recon was done at 119k. 2012 SDV6 - it's missing a couple of cylinders
Post #498577 Mon Jun 13 2016 8:37pm
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
Is it still possible to have the gearbox flushed if it states in the manual 'filled for life' ?
Yep, I'm that stupid..........................
Post #498615 Tue Jun 14 2016 12:00pm
Yes it is.
"sealed for life" just means that the car manufacture doesn't recommend an oil change interval.
Maybe they can't be bothered to design tooling to have the oil changed once in the gearboxes life.
Post #498618 Tue Jun 14 2016 12:45pm
Brutus
Thanks for the response
Post #498621 Tue Jun 14 2016 1:32pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Re: Powerflush
Hi Pete,
How is it that your 2006 is still under warranty? I know I'm in Canada but I'm still wondering how a 10 year old RRS can still get an extended warranty. Is that the case or are there some components of Land Rovers that are warrantied for life.... ?
Neutral
Post #498632 Tue Jun 14 2016 4:21pm
There is no need to be jelious.
Our used car warranties aren't worth the paper they are written on. Laughing
Post #498640 Tue Jun 14 2016 5:45pm
CANROVER
Haha mine was. It saved me 30k worth of repairs and maintenance, not to mention the loaner fees.
Post #498641 Tue Jun 14 2016 5:49pm
Plazmapete
Only got the car a month ago. The garage gave me a 3 month warranty.
Post #498646 Tue Jun 14 2016 6:18pm
CANROVER
AHHHHHHHHH.. OK thanks
Post #498652 Tue Jun 14 2016 7:29pm
Yes I have seen Doug DeMuro on youtube recommending bumper to bumper warranties on your side of the pond.
Post #498653 Tue Jun 14 2016 7:53pm
He is legally responsible anyway. The warranty is his attempt to get someone else to blame... 2012 SDV6 - it's missing a couple of cylinders
Post #498659 Tue Jun 14 2016 8:23pm
I'm glad you mentioned that.
What is the legal position in the UK ? when purchased from a trader.
3 months ? covering what ?
Post #498661 Tue Jun 14 2016 8:48pm
Johnski
If anything is found wrong with a used car purchased from a dealer in the UK, they have to by law repair it, if the fault appears in a reasonable amount of time. Trading Standards are saying minimum of a year.
Used LR RRS purchased from LR approved dealer network give a minimum of 24 months Warranty, extendable by the purchaser. Comes as a rule with two years MOT pass or they pay for repair (except tyres, bulbs, window wiper blades etc. And a half day off road experience and other goodies. John
Post #498672 Tue Jun 14 2016 11:18pm
Brutus
So, back to the powerflush. Does the flush include the torque converter or is it just the gearbox?
Post #498692 Wed Jun 15 2016 9:07am
