Home > Maintenance & Modifications > Powerflush
includes everything.
Post #498700 Wed Jun 15 2016 10:26am
Plazmapete
UPDATE.
Car booked in for flush. The oil is £20 a litre. New filter and pan kit is £130. All in its costing over £400+ VAT. Better be worth it.
Post #498880 Fri Jun 17 2016 4:21pm
That's not a power flush, that's a standard Land Rover filter and fluid. A power/mega flush would be £250ish. The standard filter and fluid change doesn't change all of the oil - it changes about half of it because much of the oil is held in the torque converter and doesn't drain when you take the pan off. 2012 SDV6 - it's missing a couple of cylinders
Post #498887 Fri Jun 17 2016 5:26pm
Plazmapete
Yes it's being powerflushed. And having new filter and pan fitted at the same time.
Post #498891 Fri Jun 17 2016 6:09pm
That'll use a bit of oil then. You'll lose half of it when you drop the pan then presumably it needs to be filled to level before the powerflush because the oil needs to be at a certain temperature which requires the gearbox to be run. So you're using 1.5 times the normal amount of oil. Is this at a LR dealership? If so, check they are actually going to do a dialysis flush rather than what they call a flush - which is as I described earlier just a flush of the box. 2012 SDV6 - it's missing a couple of cylinders
Post #498896 Fri Jun 17 2016 6:44pm
Plazmapete
Not at land-rover dealership.
Think the garage will change filter and pan after the flush once the old oil has been removed and new oil replaced. They are also putting some sort of treatment/additive in with new oil.
Post #498905 Fri Jun 17 2016 8:01pm
Plazmapete
Car running nice and smooth. Should be at just over £500 for megaflush 9 litres of oil and new pan and filter.
Post #499476 Sat Jun 25 2016 2:19pm
