![]() | Home > In Car Electronics > Is there phone connectivityfor RRS 2006 |
Use fuse 19 or 47 as an aux ignition supply |
So I guess you refit the 15A fuse into the holder to do its factory task
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Ok. So it is a 5A fuse.
Oh lordy.
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
I might be missing the point here. I have a 2006 RRS S/C . It has the 'Nokia ' phone cradle in the lid of the centre console which is now pretty useless for I and smartphones.
@Cracka - i don't have the bluetooth module in the back. Hence no bluetooth connectivity.
There is a little red tool in the fusebox for removing the fuses. It's great and works well. |
I generally use a pair of very long taper nosed pliers to remove and fit fuses, find they work well especially if you have hands the size of a shovel.
ok, i bought a little red fuse removal tool that didn't work, long tapered pliers did the trick perfectly.
Would really love to have some insight into how people have stored all this extra cabling behind the stereo?
There is loads of room on top of the stero. |
Thanks all for the advice. Had a mate come round today and he sorted out a live feed from the steering column. As for the wiring harnesses, chopped them all shorter and reconnected them. Was still a tight fit but the Parrot is now operational and works like a charm. And the sound is actually better than the factory installed radio.
