Home > In Car Electronics > Is there phone connectivityfor RRS 2006 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Use fuse 19 or 47 as an aux ignition supply |
Wed Jun 08 2016 5:42pm |
So I guess you refit the 15A fuse into the holder to do its factory task
Thu Jun 09 2016 11:06am |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Ok. So it is a 5A fuse.
Thu Jun 09 2016 1:50pm |
Oh lordy.
Fri Jun 10 2016 1:59pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
I might be missing the point here. I have a 2006 RRS S/C . It has the 'Nokia ' phone cradle in the lid of the centre console which is now pretty useless for I and smartphones.
Fri Jun 10 2016 10:34pm |
@Cracka - i don't have the bluetooth module in the back. Hence no bluetooth connectivity.
Sat Jun 11 2016 4:03am |
There is a little red tool in the fusebox for removing the fuses. It's great and works well. |
Sun Jun 12 2016 8:47am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
I generally use a pair of very long taper nosed pliers to remove and fit fuses, find they work well especially if you have hands the size of a shovel.
Sun Jun 12 2016 9:10am |
ok, i bought a little red fuse removal tool that didn't work, long tapered pliers did the trick perfectly.
Sun Jun 12 2016 11:26am |
Would really love to have some insight into how people have stored all this extra cabling behind the stereo?
Mon Jun 20 2016 4:46pm |
There is loads of room on top of the stero. |
Mon Jun 20 2016 10:18pm |
Thanks all for the advice. Had a mate come round today and he sorted out a live feed from the steering column. As for the wiring harnesses, chopped them all shorter and reconnected them. Was still a tight fit but the Parrot is now operational and works like a charm. And the sound is actually better than the factory installed radio.
Tue Jun 21 2016 7:46pm |
