Home > In Car Electronics > Is there phone connectivityfor RRS 2006
Page 1 of 4 1234>
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Hi,
looking at getting my first RRS, i'm used to creature comforts such as bluetooth and my iPhone connecting to the car and streaming my music. My budget allows for a 2006 - 2008 car.
I've seen the one in the link below, it has the green adn red buttons for answering phone calls, but i couldn't see anywhere the connection for a phone, i understand Bluetooth wasn't introduced until 2010 models?
What are the options as aftermarket add on?
http://www.nettiauto.com/en/land-rover/range-rover-sport/7980377
cheers
Steve
Post #494506 Tue Apr 26 2016 7:06pm
There will be a useless dock connector under the console lid.
I think you can upgrade the standard system to BT for Ł300? Ish.
Or you could fit an aftermarket system for half that.
I'm not sure how you can do stero music streaming on the RRS.
Post #494515 Tue Apr 26 2016 9:03pm
TheWojtek
Re: Is there phone connectivityfor RRS 2006
It's been there since 2006. It's just that the original module is crap, search the forum for 'bluetooth upgrade', it's been answered a million times, and then get in touch with Ian.
And no, there is no factory-looking BT streaming solution. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #494526 Tue Apr 26 2016 10:06pm
Tim in Scotland
A "hands free" system has been available on D3 and RRS since launch but it was optional and needed a cradle under the armrest in the Centre cubby box. It became a standard fitting in 2007 and the cradle was done away with in Sept 2007 for 2008MY cars.
You will find that the early system is not great and is quite basic, a Parrott or similar aftermarket system will give you everything the LR system gave an d more seamlessly and less expensive......... It might even be worth your while upgrading the original audio system to one with DAB and BT if you decide to go for an aftermarket system. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #494538 Wed Apr 27 2016 6:52am
Pakolainen
Hi chaps,
thanks for the responses.
Picking up the car tomorrow, it will be my first RRS. Looking forward to it. I will then be able to play around and see what's what.
cheers
Post #494702 Thu Apr 28 2016 5:57pm
tom0311
United Kingdom 2009 Range Rover Sport Supercharged Autobiography Santorini Black
The standard bluetooth on my 2008 RRS works fine. Easier and faster than the 15 plate C250 I've spent the last year in. Only downside is I have no idea how to mute the mic.
If only they had put bluetooth audio in!
That's a similar spec to mine except you've got a sunroof whereas I have side steps. Enjoy Smile
Post #494704 Thu Apr 28 2016 6:32pm
Pakolainen
Have now has the car for 2 days. There is no phone cradle in the centre console. HAve searched posts and web results for where the AUX port is, everyone points me to look at the back of the centre console under a panel. But i have nothing, just 2 small cubby holes for possibly storing a mars bar. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #494855 Sun May 01 2016 4:29pm
I think under the vents is a panel which lifts up to show a lighter power socket and aux.
Post #494860 Sun May 01 2016 6:07pm
Pakolainen
This is what i have in the back of the centre console and in the back of the boot right hand side. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #494863 Sun May 01 2016 6:33pm
See here:
http://www.ebay.co.uk/itm/2005-2011-RANGE-...SwLitXET41
you should have these under the lid of the center console arm rest for a phone cradle
http://www.ebay.co.uk/itm/Land-Rover-Disco...SwpoJXDpOc
Post #494869 Sun May 01 2016 7:10pm
Pakolainen
Don't have the cradle in the centre console, but from what i read it's pointers anyway.
As for the eBay Rear console facia, would it not be easier (cheaper even) to remove the radio and insert headphone cable into the AUX port and then run it to the inside of the centre arm rest console? 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #494872 Sun May 01 2016 7:38pm
Yes it would Thumbs Up
I wasn't suggesting you buy one, just showing you a picture of where it is normally fitted
Post #494873 Sun May 01 2016 8:03pm
Pakolainen
Thanks. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #494875 Sun May 01 2016 8:07pm
[URL=]
[/URL]
The aux wires are the red and blue and ground on the left connector.
Follow the blue wire to see which cable is goes to, to see which red and earth it is
Post #494879 Sun May 01 2016 8:44pm
TheWojtek
Check for bluetooth module under the flap in the boot (right-hand side panel). Regards etc.,
Wojtek
Post #494923 Mon May 02 2016 9:51am
Page 1 of 4 1234>
