Home > General > black oil in expansion tank
Dave_telford
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
hi I have got some black oil in my expansion tank I have had the oil cooler change has anybody had any experience with this problem thanks
Post #495543 Tue May 10 2016 9:07am
Bodsy
Site Sponsor
I've not seen that before, wonder if the head gasket has gone? Changing the oil cooler? Autobox oil or engine oil cooler?
Autobox cooler is part of the radiator. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #495623 Wed May 11 2016 7:00am
Dave_telford
Sorry perhaps the full story might help the car went to telfords 4x4 specialist's for a leaking water pipe under the supercharger while it was there they then spotted the dreaded cream like gunge in the header tank there expert instantly said he knew what the problem was the engine oil cooler so I had it changed at the same time. from then I checked it on a regular basis's and had some little oil getting back thinking this is probably what was left in the pipes . 5months later and I am still getting black oil in me expansion tank I have checked the oil filler cap (clean ) plus there is no indication off water on the dip stick
Post #495637 Wed May 11 2016 8:32am
Might be worth trying to flush cooling system with something like this a couple of times, and see where you go from there. If it keeps reappearing you may well have other issues but worth a try first.
If Oil has got into the system it will always keep coming to the surface for obvious reasons and will take a very long time to disperse.
http://www.forteuk.co.uk/product-detail/39...stem-Flush
Only a suggestion.
Post #495641 Wed May 11 2016 9:03am
Socast
I wouldn't have thought it would be black though, if the oil has been sat in the coolant for awhile surely it would emulsify ?
If it's leaving black scum at the top of the header tank then yeah a flush is the way to go, if the oil isn't emulsified then it must be being drawn into the system somewhere close to the header tank for it not to mix.
Post #495661 Wed May 11 2016 1:41pm
Dave_telford
thank you very much guys I will try a flush first
Post #496040 Sun May 15 2016 6:39am
